BB Caddy motor ID
Discussion in 'The Garage' started by mudhound72, May 8, 2005.
  1. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    I have a BB Caddy motor in my Burban that I bought think it is eather a 472 or a 500ci, is there a way to find out what I have without a tear down or pulling it out.
    All that I know is that a 500 was made in 75-76.
    It has a HEI, a q-jet, and a egr, cast iron intake.
    Anyone have a clue, are there some easy casting numbers to find and if so what are they.
    Todd
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  3. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Pull out one spark plug and turn the motor over manually, measure the stroke. To do this, put a welding rod in or coat hanger into the cylinder, and turn the engine manually until the piston reaches TDC.Mark the rod. Now turn the motor manually until you reach BDC. Mark the rod. 500 will have 4 1/4" stoke, 472 has a 4" stroke. Hope I explained that properly.
  4. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
  5. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    There was some cam talk at http://www.hwforums.com/2089/ awhile ago about cams. The 1970's OEM cams were hampered by emissions requirements and therefore VERY POORLY designed. Do a search and maybe you'll find the thread (I believe Lynn Nichols on that board had a very good post about the subject). So basically, one of he best upgrades would be a MT3 or MT5 cam to replace the OEM slug stick in there right now.
  6. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    I did some reading into perf up grades, and it would not take much to pick up HP, and still keep gas mileage. A cam would be the #1 thing to do, that and it sounds like I have a stuck lifter :(
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hp?
    how much hp and tq did those bad boys crank out stock?
  8. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
