BBC alternator brackets
Discussion in 'The Garage' started by 77crewcab, Aug 18, 2005.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Any one know where I can get factory style alt bracket set including bolts and spacer or individual pieces like the bolts and spacer. I have the top mount but am missing the bottom mount and spacer and the bolts to mount the alt with are FUBAR. All I can find is the top and bottom mount but no spacer or bolts. There were some on ebay a while back but no longer. Also could someone post or email pics of the factory ac brackets that connect to the compressor itself. Mine look factory with an extension piece added to space the compressor out some. Just want to see how the mounts on the sompressor are supposed to look.
  2. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Your looking too hard. The spacer and bolt are the same as the ones on a small block.
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    So I should be able to get them off any small block in a salvage yard? If I can't find them where could I buy them Summit, Jegs?
  4. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    salvage yard.
  5. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thanks I have been going nuts trying to find that spacer and correct bolts, didn't know they were the same. By any chance is the top mount braket the same too, the one with the adjusting slot that mounts to the intake and water pump?
  6. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    The top mount and lower front triangular brackets are different. Like Thor said the spacer and bolts are the same as an sbc. I would hit Ebay if you can't find a salvage donor, there's lots of brackets on Ebay.
