BBC engine block
Discussion in 'The Garage' started by k5s10, Dec 13, 2006.
  1. k5s10
    k5s10 Registered Member
    Sep 22, 2002
    76
    Choctaw, Oklahoma
    I pulled this motor from a 89 1 ton dually the block code #14015445 says to be 78-90 block.Behind the flywheel it says HI PERF PAS below this a backwards 5 and a backwards 4.Anyone know what 454 I have? Is this motor a basic stock motor or does it have factory performance internals?Thanks
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Just a garden variety 454 with peanut port heads.
  3. 87'k5boggin
    87'k5boggin Registered Member
    Dec 9, 2006
    76
    pascagoula,mississippi
    their is a web site where you can type in the block number and it will tell you all about the motor but i forgot the site. sombody on here is sure to know it if it came out of a dually it should have the high torque heads.
  4. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    seems like all BBC had Hi Perf Pass on them.
  5. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
  6. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Mortec.com
  7. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    The "Hi Perf Pass" designation reffers to a high performance passenger vehicle block. I forget what makes a "Hi Perf" block different, but I believe all later Mk IV blocks were denoted as such - IIRC my Chevy Power Manual says what "Hi Perf" actually reffers to. The "PASS" part means it is a short-deck block (9.8" deck height) designed for passenger vehicles and light duty trucks. GM also made a tall deck (10.2" deck height) Mk IV block, which was only used in medium duty (greater than 1 ton) trucks, and only in displacements of 366 and 427 cubic inches. GM never made a tall deck 454 to my knowledge.
  8. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    this it all the info mor tec has on it.
    14015445...454.......78-90...2 or 4 bolt
    yes GM did make a 454 Tall deck here are the casting numbers
    10134366...454T..............4-bolt, Bowtie, Gen.V, Tall deck
    14044807...454T..............4-bolt, Bowtie, MkIV, CNC prep, Tall deck, 4.25" bore or 4.495" bores
    24502506...454T..............4-bolt, Bowtie, Gen.V, Race prep, 10.2 "tall" deck height
  9. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Those are Bowtie blocks. What I meant was that GM never made a production tall deck 454, i.e. they never used it in any production vehicles. Also, a 427 and a 454 both have the same bore size (4.25"), so one could build a 454 on a tall deck production 427 block simply by installing a 454 (4.00" stroke) crankshaft. Thus the nomenclature "454T" doesn't really signify that it is a "454" block, but simply that it is a 4.25" bore block, just like the factory 427 tall deck block.
  10. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Yes I agree 100%:wink1:
