BBC head info again....
Discussion in 'The Garage' started by SUBFAN, Dec 23, 2004.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    048
    049
    045
    063
    Four castings available....Are the 048 and 049 the same, there is 1 of each....
    The 045 looks to be a closed chamber....
    Is the 063 what is referred to as the peanut port?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'm not real up on BBC but I know the 045 heads aren't that good. They are the small oval port heads. I think they are the ones refered to as peanut ports
    The 049 is a good head for a 454 they are the large port open chamber. But you need the matching intake.
    There are diferent intakes for the large port and the small port.
    The 063 was used on 427s 396 ect. I think it is a performance, closed chamber, High compression ratio head
    Dont know about the 048
  3. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    A 781 is a near identical match to an 049, none of the others listed.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i run 049's on a 69 chevy 2wd. u can make a lot of power w/ them. u just need a domed piston to get the compression where it needs to be. they have 122cc combustion chambers
  5. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Anybody know about that 048 head? Is there such a critter? It sure looks like the 049....
