BBC Heads
Discussion in 'The Garage' started by burbanbeast, Feb 4, 2007.
  1. burbanbeast
    burbanbeast 1/2 ton status
    Jan 24, 2006
    103
    Collierville
    are the intake bolts all the same on BBC heads? or are they like sbc? the reason im wonderin is im doin a TBI swap on big block and im figurin instead of buyin the carb to Throttle body adapter i would probably get better results and performance gains if i use the edelbrock TBI manifold. set me straight please
  2. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    there 3/8s so they will be easy to get homr depo or any hardware place
  3. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    If you are talking about Mark 4,5 and 6 the intakes are all the same bolt pattern and orientation. Head gaskets and water passages are a different story.
