BBC into gen 1 k5. Crossmember built
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MNorby, Oct 2, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Going to put the 454/ TH400/ Doubler into the 71. It is currently in an 83 frame. What do I need to know about motor mounts? Will the ones from the 83 fit? Crossmember clearance? It has HEI and tall valve cover to cleare roller rockers. I am putting a 1" body lift on the rig. Will I need to do some creative BFH mods to firewall to fit it? It also has hedman headers, will they fit? Looking in a jegs mag it looks like the application could be the same. Any other tips regarding the swap?Thanks
  2. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    Move the front crossmember forward about 2 inches and that will cure your firewall issues, just make sure you check clearance to the radiator, but somewhere around 1-2 inches makes a big difference. Use the first gen motor mounts, they will bolt up. Headers may work, you may have to space the mounts up a half inch to make the tubes clear the crossmember.
  3. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I have read alot about using 73 and newer truck engine crossmember, did you do that or just take the stock one and move forward? I will also use the 4 core radiator and prob continue to run electric windstar fans
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Burt4x4 used the 73-up crossmember and had just minimal firewall mods to make - he has a body lift. I used the stock crossmember and had to do considerable firewall mods. If you move the engine forward, keep an eye on your front driveshaft angle to make sure it doesn't get too severe. Keep us posted and be sure to post pics of your swap.
  5. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    front shaft shouldn't be too much deal being as going doubler so moving forward will help rear shaft angle. What about full length header clearance with the stock crossmember?
  6. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
  7. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    does anyone have pics of normal 73-87 type headers in the gen 1 rigs with the 73-87+ type crossmember installed? hang down issues?
  8. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    we put a big block in my dad's 71 and had no real issues. Used the stock low boy valve covers and it cleared the fire wall. used the stock 71 crossmember in the stock location with the stock 71 motor mounts and everything bolted up.
  9. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    bdozeraz, what did you have for exhaust?
  10. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    well got then 350/465/205 out this weekend and got my 454/th400 out of the other rig and ready to strat the swap. I want to move the engine forward an inch or so forward for firewall clearance and driveline lengths. Here are the 80s style engine mount towers bolted in the frame with the center of mounts roughly 1 inch forward. I messed around with the 80s style crossmember but it looks like a hack job to use it so gonna build something like this out of 1.5x3/16" sq tube. Opinions?
    I already have the scale blueprints drawn out. Should have 1" clearance from oil pan. This drawing was just for visiual aid.
  11. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    If you can, try moving the axle forward the same amount (1 in) to stay 'neutral' with rig balance.
    Ideally though, the engine should be behind the front axle (i.e. engine pullies should be at, or behind, the front axles.
    Good luck and keep the pics coming :D !!
  12. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    i have already moved the front forward 1.5" with a zero rate and will prob a little more when I do 52s in the front
  13. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    crossmember built
    crossmember built out of 1.5" 3/16 sq tueb, just need to make mounting provisions.
  14. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    looks beefy.
  15. Clockwork71
    Clockwork71 Registered Member
    Mar 23, 2006
    23
    Waukesha,WI
    I think with the new motor mounts you should be able to run any 73-87 headers with little or no frame mods. I kept the original crossmember and motormounts and used doug thorley 304-y headers. I had to grind the frame for the second header tube on the pass. side. I would recommend using short valve covers if you can. You will have less firewall clearance issues. Also, i think your box steel engine crossmember will work good. it looks like you won't have any clearance issues if you use crossover steering.
  16. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I am using my ord crossover steering from my buggy so it already has a bent draglink but it will clear by a mile. I have to run tall valve covers because of my roller rockers. Found out the hard way when I put the engine in and was putting the tin on the stockers wouldn't clear.
  17. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Very clean looking crossmember. You do great work.
  18. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    :bow: :bow:
  19. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    works on more tonight but didn't have time for pics. drilled my7/16 holes that bolt it to the engine mount brackets out to 7/8 and put some bushing material in there so when the bolt it tightened down it will be tight against the bushing instead of trying to squeeze the tubing together. Will take pics tomarrow.
  20. bigblock72
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    That crossmember looks great! Quite impressed with how it turned out. The later style motor mounts are ton stronger than the early style, I think the motor should fit nice with what you're doing.
