BBC Motor Mounts (SBC too)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Shawn, Feb 12, 2001.
  1. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Just some info for people considering swapping in a BBC or have a torqy SBC.
    Been told by many that I should be using a BBC motor mount for my Blazer (currently using stock 350 motor mounts). Supposely the rubber in the BBC mounts is better or has more of it. Ok fine. Go to NAPA yesterday and asked for a K30 motor mount with a 454. Get the parts go home and guess what, don't fit, both sides. Take them back to find something else. Nothing else will work with my frame/crossmember, not even 3/4 ton mounts so I'm stuck with stock 1/2 ton SBC mounts.
    Called 4 Wheel Parts today and asked them about Energy Poly mounts. They have them in stock so I go and take a look. Much more poly compared to the stock 1/2. 3/4 and 1 ton rubber mounts. I think these Energy motor mounts will do the trick for a BBC. Wouldn't hurt to have these even if you had a HP small block. Just passing on the info.
    Can be seen here:
    http://www.off-road.com/chevy
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    On a truck originally equipped with a big block from the factory, the motor mounts are different than the small block. One of the holes are in a different location than the other. Just my .02 worth.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey Shawn dude,
    What about ORD's motor mounts? Did you conatct Stephen ??
    Are they Energy brand also? Just curious....
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  4. Shawn
    1,753
    5
    5280'
    The K30 mounts had the wrong bolt locations plus one was "stepped" and there was no way it would work.
    I think ORD's might be a better design but they do cost a little more ($150/pair compared to $50/pair). Also, Steve Fox uses the Energy's with no additional engine vibration where the ORD's mounts may cause more vibration. If I do have problems with the Energy's then I will switch to ORD's and pay a little more.
    Shawn
    87 K5
    few mods[​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
