BBC oil pressure switch?
Discussion in 'The Garage' started by GRAYTEXK5, Oct 21, 2005.
  1. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    Can someone please tell me where the oil pressure switch goes, on a late 70's 454? the only place I can see that it would possibly go, is right above the oil filter. the previous owner of the motor had 3 adapters screwed in there, getting smaller as they go...and that's it. if I take out the smallest one, I can screw the pressure switch into the next one...but it seems like it sticks out really far, and it just doesn't look right to me. if anyone has any pics of where and how this should be mounted, that would help a lot. thanks.
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Mine was right above the oil filter too. Thats the only place that comes to my mind. You can get shorter adapters.
  3. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    Mine was just above the oil pan, drivers side almost all the way towards the front. Above the oil filter was capped on mine with a screw in plug. This was on a 79 454
  4. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    above filter is factory spot.
  5. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    There is an oil passage that runs the length of the block. The hole above the oil filter taps into it. There should be 4 holes (maybe 5) total spaced along the block, all 1/8" NPT. Then there is a hole in either end of the block (front and back) where the oil rail was drilled, and the plugs in this are larger (3/8" NPT maybe). You can plug all the holes if you want, or tap into the oil rail anywhere along it. Hope this helps.
