BBC PS BRACKETS
Discussion in 'The Garage' started by aj_johnson, Aug 12, 2003.
  1. aj_johnson
    aj_johnson Registered Member
    Jul 20, 2003
    40
    I just got my new Power Steering brackets for my 454 today, they are a 3 piece setup... will someone that has a BBC PLEASE take some pics of their PS pump so that I can see how they go together????
    email them to me at AJ@fretel.com
    Thanks guys!
  2. aj_johnson
    Jul 20, 2003
    40
    please help guys...
  3. aj_johnson
    Jul 20, 2003
    40
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I don't have a camera, but they only fit together one way, do it piece by piece, with the water pump mounted, and the p.s. pump in your hand. That's how I fit mine together. /forums/images/graemlins/eek.gif
  5. aj_johnson
    Jul 20, 2003
    40
    thanks man.. I tried it already a couple of times already today, and I still can't figger it out... that's why I need some pics! I appreciate the input tho..
  6. aj_johnson
    Jul 20, 2003
    40
  7. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    My bbc only has 2 brackets like the ones I found pictured in this Ebay auction;
    **The pulley will have to be removed from the pump to install the brackets.**
    The flat bracket with the square hole goes on the front/top of the pump with the hole towards the water pump. The pump sits down inside the "U" shaped backet, the bracket is postitioned so that the 2 bolt holes touch the face of the block and the tab touches the drivers side of the block.
    This is how mine is set up, I have a tear drop type pump with the resevoir attached.
  8. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Those are the correct one's.
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    OK, then I'm confused.....that's what was on my 396 originally when I got it, along with the teardrop shaped ps pump.
    I just bought a round pump and remote resevoir which was claimed to be a "big block" setup...the lower pump bracket is WAAAAAY longer and puts the pump almost directly over the framerail...the belt needed was something like 54" long!!!
    Anyone care to comment on what the heck I have installed now!???? /forums/images/graemlins/confused.gif
  10. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    I've seen both styles on bbc's. TARussell had an 84 K30 dually, the 454 in it had a round pump/remote resevoir set up like you got. When I did my bbc swap I bought all of my brackets for a 74 454 Sub.
    I dunno... year models maybe? /forums/images/graemlins/confused.gif
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Well it's cool having a "Factory" setup that actually has the remote reservoir....theoretically, it should hold more fluid in the canister and hose, than a standard "teardrop" shaped PS pump..... and extra fluid is never a bad thing when you start running hydro assist!
    Thanks for the validation, and the quick history lesson. /forums/images/graemlins/cool.gif
  12. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Mine were for a '76 peekup with a BB, teardrop can. /forums/images/graemlins/shocked.gif
  13. aj_johnson
    Jul 20, 2003
    40
    here is the setup that I have....
  14. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    A come's off the block, and one threaded hole ahead of the motor mount, B fit's on back of the pump, C is an "adjuster" bracket.
    It take's some dinkin around but they fit together. You will also need to use some "thin" 3/8" washer's to space the pump to get the belt to run straight/true.
    I think I had to bend and tweak the bracket's to fit good together.
