Bbc Questions***interchange***
Discussion in 'The Garage' started by bigbadchev84, Jul 18, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    what parts off a small block will work on a big block? i have a 66' 396 that i am gonna drop into my truck but it is missing quite a few pieces. so what can i re-use from my small block? distributer, fuel pump, push rod for fuel pump, etc. any help would be great!
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    distributor will work, fuel pump I am unsure about, but I believe they are different. I seem to remember hearing that it will bolt up, but it wont operate properly. I run an electric, so cant say with certainty.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I think the BB pump lever is longer . Would have to look at one of Shawns BB's to remember . Been so long since I tore one down ( a 402 in 1992 , ate a bearing , still started and drove the dude home ) .
    So basically just the distributor and carb .
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    bbc
    Distributer, Motor mounts and not much more. Yes the pump arm is longer on a big block.
  5. diesel4me
    Jul 24, 2003
    17,581
    945
    Massachussetts
    some stuff fits..
    The fuel pump from a small block WILL bolt on--but it will snap it in two in short order!--its just different enough so it wont work!--I learned this on a dark road the first day I got a truck with a 454 on the road! :doah: --after busting my butt to put the smallblock pump on,I got exactly 1 mile away before it died again,and now the pump was hanging by the hoses! :doah: :mad: ..I walked 3 miles home and got a universal electric fuel pump off my plow truck so I could limp it home!..
    I think the pushrod for the fuel pumps are the same as a small block..the distributor is the same..your biggest dilema will be pulleys and brackets for the P/S and altenator...nothing from a small block will work right...you might have to buy aftermarket ones..pretty hard to find used ones anymore.. :crazy:
  6. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    parts interchange
    hello dude the dist will work if the block is not a truck block its 400 thousands taller different intake and longer pushrods but steel good tq motor . Also i useed smallblock pullys on it but had to use 1/4 spacer on harmonic balencer :hack:
