BBC Serpentine???
Discussion in 'The Garage' started by ak bandit, Mar 23, 2005.
  1. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    If you are gonna get it, try www.gmpartsdirect.com ...from what I punched up...after shipping its about $100 cheaper than the site you posted:saweet:
  3. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    Cool...Thanks...Now if I can only figure out if it will work for a Mark IV BBC :dunno:
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Dunno for sure, but it will probably require a reverse rotation long water pump.
    If you get a concrete answer I'm interested as well. I'm running a MarkIV 396/402 with milled 454 OC heads.
  5. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    I called the local Chevrolet Parts and Services department and they were unhelpful (as usual). I didnt get a yes or a no whether it would fit or not....
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The real pisser is that they don't sell the kit without the a/c compressor and power steering pump. I don't need either of them. :mad: I guess I'll take their parts list to the local dealer and see what it would cost to buy the rest of the stuff individually...
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    buy it all in the kit and sell the new on ebay. have you seen the prices on the a/c comp alone. just a idea. and you might actuly make some money back also.
  9. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    I believe it comes with a water pump. Basically EVERYTHING you need to convert over
  10. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    The first part number he posted is a kit without the a/c compressor i think? Its a bit cheaper too.
    The description is the same for both, but when you place the order, it specifically says w/o a/c.
    Different part numbers for the kit with a/c and the kit without a/c
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That kit is for non-air-conditioned vehicles. :blush: The brackets are different, although they use the same picture for both kits. A black Suburban NEEDS a/c! :cool1:
  12. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I have this info saved from a while back.
    HTH
    BBC Serpentine List With AC
    11/29/04
    Category 7 of 14 >>
    << Product 7 of 8 >>
    Big Block Accessory Drive (with air) # 12498733
    Note: Typical picture shown. Product may be different from shown.
    SKU: 12498733
    RETAIL: $915.00
    PRICE:
    $777.75
    Description
    This deluxe serpentine belt drive system with air conditioner includes the componets to install on a standard 9.80" deck or the 10.20" tall deck Chevrolet block. The bolt, nuts, spacer along with all the parts listed below.
    Part QTY Description
    10463415 1 Generator Asm-reman CS130
    26010328 1 Pump Asm-Power steering
    12456326 1 Pump Kit, Wat
    01134343 1 Compressor Asm, A/C R4
    10187612 1 Bracket-A/C Cm0pr
    10187613 1 Bracket-A/C Cmpr
    11515757 1 Bolt-Metric HeavyHex Flange H
    10108470 1 Outlet-Water
    10105135 1 Gasket-Water Outlet
    11514189 3 Bolt-M10 x 1.5 x 105.0
    11518034 1 Bolt-Heavy Hex Flange Hd
    10085753 1 Pulley Asm-cr/shf
    11516328 1 Bolt,Hfh
    09440226 3 Bolt-Flg Hex Hd .375-24 x .625
    88986828 1 Belt, W/Pump and A/C Cmpr and Generator
    09442911 1 Bolt/Screw-7/16 x 14 x 4 1/4
    88986813 1 Belt, Fan, W/Pmp, and A/C Cmpr
    12552359 1 Tensioner Asm-Drv Belt
    12552361 1 Pulley Asm-Belt Idler
    10085760 1 Pulley-Fan and W/Pump
    06272959 2 Connector-Therm Bypass Hose
    01470030 2 Clamp, Worm Type (11/16" to 1 5)
    01485552 1 Hose Water Heater .750 ID
    12573728 1 Pulley Asm-P/S Pump
    11515767 3 Bolts Trans BR Brkt
    88961892 1 Bracket, Tall Deck Power Steer
    10187611 1 Bracket-Gen Fr
    10187610 1 Bracket-Gen and P/S Pump
    09442963 5 Bolt Hex Flg Hd
    11515756 4 Bolt-Metric Heavy Hex Flg Hd
    10224224 2 Stud-Gen and P/S Pump Brkt
    03930109 2 Nut-Hex Flg
    10255857 2 Nut-M10x1.5 Flanged Hex Head
    10244168 3 Bolt/Screw-3/8 x 16 x 4 1/4 FL
    11516109 1 Bolt-Metric Heavy Hex Flange H
    24572579 1 Bolt/Screw-Tmg Chain HSG
    11515754 4 Bolt-Metric Hvy Hex Flg Hd(M8)
  13. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    And this.
    BBC Serpentine List Without AC
    11/29/04
    Category 7 of 14 >>
    << Product 8 of 8
    Big Block Accessory Drive (with out air) # 12498741
    SKU: 12498741
    RETAIL: $665.00
    PRICE:
    $565.25
    Description
    104633415 1 Generator Asm-reman CS130
    11516328 1 Bolt,Hfh
    10055890 1 Pulley, Idler
  14. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    Cool deal...Thanks for the info.
    What is the difference between the Mark IV and the Gen V BBC's?
  15. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Are you sure the brackets are different? I mean the main brackets or? My '90 had a/c and when the pump took a crap, I just went and bought the idler pulley that bolted right into the original a/c pump position. Worked like a charm.
    Wonder if it is that simple on the big blocks?
  16. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    I'm not sure of anything :dunno:
    I have a long block 396BBC that needs all the brackets, pulleys, and accessories...That serpentine drive kit isnt a bad deal considering it includes everything you need. I just dont want to order it and the thing end up not fitting...
  17. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I'm looking to do the same on a BBC I have sitting in my garage.
    I took the kits and put there part numbers in an excel spreadsheet.
    The only difference in part numbers is:
    A/C kit has these extra parts:
    The Non A/C kit has this extra part:
    ALL OTHER PART NUMBERS ARE THE SAME.
    The funny thing I did notice is that both kits come with two belts:
    I don't think (that is usually my problem ;) ) that the external bolt holes are different between gen IV and V and VI BBC's, but I could be wrong. I think the differences are mostly internal with the newer blocks not having a fuel pump boss. If that is the case these kits should work for us.
    My only concern is the A/C pump and brackets. My truck did not originally come with A/C so I will be putting a vintage air a/c unit on my truck. I am hoping that it can use the GM pump that comes with the kit or that the vintage air pump will bolt into the GM bracket.
    If you find out for sure that it will/won't work, please let me know.
    Chris
