BBC V-Belt pics w/ AC
Discussion in 'The Garage' started by rcamacho, Jan 10, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Would someone post up some pics for me? I need some understanding of how the AC belt routing works (driver's side mount) with the PS pump as an idler.
  2. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Heres how mine is on my 88 dually. I will try and see if I have a picture from a different angle if you need it.
    Russ
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks Russ. Are the brackets and accessories '87 vintage as well? Looks like one v-belt grove is unused on the wp/crank/ps - assume for air injection or other accessory?
  4. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    The smog pump originally was under the alternator. I took the big combo alt/smog pump bracket off and replaced it with the smaller alternator only bracket that is on there now. Everything on the drivers side is the correct brackets for that era. The power steering pump pulley has three grooves, but only two were used. I couldn't tell you exactly how the smog pump belt was routed on this engine as I never ran it. I do know that it was on the lower passenger side though, and I am currently using all the grooves on the water pump and balancer pulleys.
    Russ
