BBC valve cover spacers??
Discussion in 'The Garage' started by Russ, Aug 14, 2005.
  1. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Does anyone know where I could find a set of approximately 1/2 to 3/4" valve cover spacers for a MK IV 454 engine that are reasonably priced? Or possibly a set of aftermarket valve covers that are not too tall to accept the factory brackets.
    I have just finished assembling my 489 stroker motor and now my stock valve covers will not fit. I am using CompCams Pro Magnum roller rockers and the adjuster nuts are about 1/2" too tall. I plan to put this engine in my dually so would like to be able to run the air conditioner.
    Thanks,
    Russ
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Russ - I don't know if there are any spacers made specifically for that but I would call Speed Unlimited in Pensacola and see if they can help.
    I had this very same problem when I had a roller BBC in my Crew cab - I just glued two ultra-thick Felpro valve cover gaskets together and did some light grinding on the end rocker bodies. The covers still cleared the A/C compresssor brackets. It worked great !
    Tom
  3. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Thanks Tom, I will try calling them tomorrow and see what they have. I think I am going to have to have at least 1/2" to make it work so even with stacking gaskets I still won't be able to get the covers on.
    Russ
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh with the covers Im running, I cant run thestock brackets. I just sweat it out, been thinking about reworking the brackets to make the compressor just mount higher, but just havent had time (yeh, 2 years and havent had time :rolleyes: )
  5. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    It will work if you get the ultra-thick gaskets and double up on them .
    Ask for John Boyden when you call Speed tomorrow and he will be knowledgeable enough to find you every gasket the aftermarket ever offered for a BBC ( he is the one who gave me the idea about ten years ago ).
    To make sure nothing leaks I would go to your local Toyota dealer and get a tube of their black silicone for engines part # 00102-00195 ( that might be an old number by now ). Trust me when I tell you this stuff is FANTASTIC and not what you get in the auto parts stores - IT WORKS !
    Ask John about the ULTRA-THICK gaskets - they are about 3/8" to 7/16" thick each .
    Tom
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  7. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I saw those from Arizona Speed/Marine. Those are crazy expensive.
    I may have to try the gasket trick, I did not realize the thick gaskets were that thick. Either that or get used to no A/C. I have been running the truck without air anyway, but was hoping to get it hooked up when I put the new engine in.
    Thanks,
    Russ
