BBC vs. SBC Flywheel...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TULSAK5, Mar 26, 2002.
  1. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    Is there any difference in a flywheel changing from SBC to BBC.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    they are the same as long as they are for internally balanced engines.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yes... possible differences!... it is a balance issue.
    The only possibility of interchange might be for an internally balanced SBC (350 and smaller) would prolly work on an internally balanced BBC (366, 396, and 427). But the 400 SBC and 454 BBC are externally balanced - having counterweights on the flywheel - so they would not interchange w/ others or each other.
    Marv
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Most small blocks had internally balanced engines so they had a normal flywheel and harmonic balancer. Big blocks and small block 400's are externally balanced and have counterweights on the flywheel and harmonic balancer. This is a general rule as I have seen internally balanced SBC 400's that use a 350 flywheel and harmonic balancer and I'm sure there are other exeptions as well.
