BDS lift is TOO tall, need to pull a leaf... which one?
Discussion in 'The Garage' started by jjlaughner, Dec 22, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    The rear is settling but the front is still standing tall. I have about 2-2.5" difference front to rear now (it use to be 1", which was not a big deal). If I was to pull a leaf on the front which one should I pull?
    1 -of course I can't pull this one
    2 -I have read a couple posts saying pull the longest one on top
    3
    4
    5 -the shortest on bottom, if I pull this one would it make the springs more flexable?
    I'm looking to drop the front down about an 1" (then I will put a 2" 4deg block in the rear (instead of the zerorate and 3deg shim -still need to measure this to be sure on the degree I need)
    (hey the poll option is gone? /forums/images/graemlins/confused.gif)
    so which one? /forums/images/graemlins/ears.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I couldent tell ya.. but thats a clean looken truck btw are those 6in in front springs?
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Call their tech support. I've found them to be more than helpfull. /forums/images/graemlins/laugh.gif
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    can't be 6in,or mine are 8 /forums/images/graemlins/rotfl.gif.wait and see if they settle more.what do you have in the rear? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    It was suppost to be 4" all spring lift. The fronts came out to be 6.5" with the ORD shackles, the rear was exaclty 4" and I added the zerorate (before the lift all fender tops where 36.5" with a nice looking rake... after the lift the front was 42.5" and the rear 41.5" (it's now about 40.75")). The rear has settled about an inch so it looks like I'm drag racing sitting still and when I take off it looks/feels like the truck is about to pop a wheelie. /forums/images/graemlins/tongue.gif
  6. boggerless
    May 26, 2003
    22,728
    96
    my brother had rear spring's built for his truck and it looked like he was driving down hill.jacked up in the rear like old hot rod's. my BDS front springs were 2in higher on the drivers side front.it's settleing.drive it and see what happens. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    yea.. they looked like 4in springs to me but I asked becuase in ur sig it say 6in /forums/images/graemlins/thumb.gif
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Yeah I figured 6" spring, .5" shackle, 1.25" Body lift and poly bushings I'm running close to 8" total over what it was less than a year ago, still feels tippsy to me. I'm going to order some 15x10 rims with a stock offset and rear spacers so hopefully that will make it feel a little wider. Even if I put a 2" 4deg block in the back it still wouldn't be level /forums/images/graemlins/smirk.gif I would like a little bit of the rake back /forums/images/graemlins/wink.gif
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Its been on for three months and 2000 miles /forums/images/graemlins/thinking.gif
    I haven't had a good place to flex it out at yet /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you said all the fenders sat at the same height but it had a rake... rake means the rear sits higher than the front so how could the fenders be the same and the back sit higher at the sametime?
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    the fender tops are not the same heigth on the front and back normally. Measure from the body line to the top of the wheel well opening in the front and back.
    found two more pics
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    see what you mean, my k5 had a bigger rake than that, had an add a leaf in the back, sometimes I hated it and others I loved the look.
  13. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I'd say pull #2 It seams to be the one doing most of the work.
