BDS spring price and other ???'s
Discussion in 'The Garage' started by mofugly13, Jan 2, 2005.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I know this has been asked before, and pretty recently at that, but I think I must be a "search" retard 'cause I can't find it. JD's Offroad quoted me $122.49 for a BDS 4" lift front spring. This is the price for ONE spring, correct? Also, I am doing a shacle flip out back with ford 57" springs and the ORD 4" shackle flip. I need to make a set of custom shackles for my app. Do I make them as long (bolt center to bolt center) as the stock shackles? Is 1/4"x2" flat bar big enough for making the shackles, if I weld in some 1"x2" rectangular tube between them?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    why are you making the custom shackles??
    yes that price is for 1 spring.
  3. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    The custom shackle is because I am using 3" wide Ford 57" springd and also need to offset the shackles 3/8" outboard due to the fact that I am using a ford front spring hangar to accomodate the 3" springs, and it spaces the spring pack farther from the frame than the ORD 1-ton shackle flip brackets that I will be using in back.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea 1/4" is prolly fine but I would go 3/8" if I could.
  5. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    How about the length? If I build them stock length, with the shacle flip brackets, that'll give me 4" of lift, right?
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    as long as you have the spring in the same location as a regular flip then it should net you 4" of lift but you might have to play with it a little since the springs are softer.
