BDS... spring rates?
Discussion in 'The Garage' started by jekbrown, Apr 1, 2003.
  1. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    I am pondering getting rid of my stiff-as-heck 4" Rancho "HD" front springs and replacing them with springs from BDS. I checked out the spring rate chart here on ck5 and didnt see bds springs listed... anyone have any numbers on them? If not, how about a comparison to other springs? (ie, "I had tough countrys and got BDSs... the BDSs are a little stiffer"...) info on spring rates appreciated! TIA!
    j
  2. DSJ
    DSJ Registered Member
    Mar 21, 2003
    33
    Reno NV
    I am in the same spot you are, I have the stiff 4" rancho's and am looking to replace them VERY soon. Any help from everyone would be great! /forums/images/graemlins/thumb.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Spring rate 425 lbs/in.
    Free arch 4.75".
    (Oh, and that's a 4" front spring)
    Those figures straight from BDS. /forums/images/graemlins/thumb.gif
  4. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    425 eh? cool beans. My ranchos seem like they are closer to 750 lbs/in sometimes. They dont even come with teflon or UHMWPE pads between leaves stock. /forums/images/graemlins/frown.gif Its surprising to me though, that the BDS springs are stiffer than even the heavy-duty tough countrys (395 lbs/in). Hmmmmmm. I guess a little stiffer would be best for me... not having an anti-sway bar any more and all. /forums/images/graemlins/wink.gif
    j
  5. heavy4x4
    Aug 28, 2002
    3,270
    Yeah, I thought that number sounded a little high when I first read it, but BDS must be doing something right because all I've heard is awesome things about how they ride and flex. /forums/images/graemlins/thumb.gif
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yepppers, the 425 is about 100 lbs softer than the ranchos on the spring rate list... and I think the type I have (HDs?) are even stiffer (they arent on the rate chart). One thing I'd like to get would be front springs that had the u-bracket + bolt things on them to hold the springs together rather than the folded over clamps that seem to promote binding of the leaves. I wish i could get the other type of clamp... maybe ones that had 2 sets of holes drilled in them... one for on-road where the bolt was right on the spring for stability etc... and one about and inch away that would really let the springs flex offroad.
    j
  7. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I was planning on running 6" Tuff Country EZ-Rides but I dont have a sway bar. How will it drive on the street
    because it should be much softer then the Superlift ones I have now. Later
    -fLeXy K20
  8. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    without an anti-sway bar super-soft springs will definitely make taking corners exciting. lol! I dunno, my lift springs are just 4" so maybe soft springs wouldnt be so bad... 6-8 springs that had super soft spring rates may make it so that when driving on-road you have to take corners very slowly etc.
    j
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Does anyone know how BDS ride & flex compared to skyjackers?
    Also besides weight is there a advantage to rough springs?
  10. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I had a pair of 6" Skyjacker Softrides, and they had the clamp with the bolt, and handled well without a swaybar. Good springs, although I am unsure how they compare to the BDS.
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    -fLeXy K20
    [/ QUOTE ] I have 6'' tuff country ez-rides (465 in lbs; very soft for a 6'' spring) with 5 1/4'' shackle (5/8'' lift) and no swaybar. /forums/images/graemlins/cool.gif
    I wasn't having many handling issues with this setup other than this: with softer springs comes more wheel travel and with more wheel travel comes more bump steer. /forums/images/graemlins/tongue.gif I put x-over on my /forums/images/graemlins/k5.gif and it pretty much eliminated that .
    Now when I put the 57''s on the back with that frontend setup all I can say is that this thing has BODY ROLL OUT THE GOAT @$$!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif
    Soft springs (front or rear) are tolerable /forums/images/graemlins/smile.gifif you realize that your vehicle is not a race car and you drive it accordingly. They are so tolerable (for me) that I will soon be swapping in front springs with a spring rate just over 250 in lbs on my daily driver.
    TC 4'' HD's are the best riding "off the shelf" springs that I have ever experienced (haven't even ridden on the ez-rides) and I would buy them in a heart beat if I wasn't up to the task of modifying hangers and such to run a spring not meant for my application or spending the $$$ on custom made springs.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    -fLeXy K20
    [/ QUOTE ] Sway bars can be aquired at almost any salvage yard. Hell, I have one in my shed you can have if you want to pay the shipping on the damn thing. It came off my 76 K5.
  13. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I have 4 inch BDS spring in the front of my truck with no sway bar, man is it flexy. I have not ramped the truck since i have removed the blocks from the rear and added bolt on Filps and longer shocks, but i am sure it will much better then before. The last time i did it i got a somthing in the 850 range, but the shocks where maxed-out and that was all that was stopping me. now no sway, 35 (past aired up 33), no blocks and longer shocks i think i will do better.
  14. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    On my K5 I ran 4" Tuff Country's with no sway bar with crossover.........handled beautifully. No issues but they were the HD variety (not sure on the spring rate) due to the M12000 winch up front.
    On the Burb I have the 6" Tuff Country EZ rides...........ran a couple of weeks without a sway bar and it still handled fine, no issues with squirrelly handling or too much sway.
    TC springs from ORD are the best value out there. Love them, come with the lowest advertised spring rates, etc. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
