BDS springs and ORD Greasable Bushings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Jun 9, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I want to run the 6" BDS front springs, but I want to put in the ORD greasable bushings and new shackles. Anyone know if this setup will work? According to the review on off-road.com/chevy the BDS bushings are bigger. Anyone running BDS springs w/ the ORD bushings? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 4" lift, 33" BFG muds
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Contact Offroad Design about this. On that review, the greaseable bushings were originally ordered for Skyjacker springs and ORD might have the correct bushings for BDS but I'm not too sure. To fix my problem, I used he BDS bushings and cut small channels on the inside for the grease. I was then able to used the greasable bolt and inner sleeve. ORD will probably need the BDS bushing measurements.
    Shawn
    87 K5
    few mods [​IMG]
    <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>
  3. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I have the BDS bushing measurements, I will call ORD on Monday if steve is back. Thanks!
    Dawson
    Raleigh, NC
  4. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Could you post the measurements and the answer you get hear? Thanks
  5. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    The measurements are
    front eye- 1.490 inside diameter
    shackle- 1.100 inside diameter
    That is what Rene from BDS told me. I will post what Steve says.
    Dawson
    Raleigh, NC
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    ORD does have two different bushing sizes for the aftermarket springs.
    One size fits the Skyjacker and Superlift springs.
    The other size fits all the other major lift company springs.
    Check with ORD for the correct part no.s.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  7. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK, I am running BDS springs w/ the greasable shackle kit. BDS springs are a bit narrower then the stock springs (in the front only), and thats why they state the bigger bushings. However, I am running ALL ord bushings up front. In the back I had to use the BDS bushings.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  8. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Rene from BDS said the big bushing companies, like energy and stuff make 3 different sizes of bushings. Ones for stock springs, ones for aftermarket springs (lift springs), and ones for skyjacker and superlift springs. He said their springs use the ones for aftermarket springs, which are bigger than the stock ones. That might mean that the BDS bushings are bigger than stock, not bigger than other companies, which would mean they are the right size for the ORD bushings. Anyone get what I am saying?
    Dawson
    Raleigh, NC
  9. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    So you do not have any problems running the BDS front springs w/ the ORD bushings and shackles? Thanks!
    Dawson
    Raleigh, NC
  10. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    no, I got no problem at all running it... works like a dream.
