BDS springs
Discussion in 'The Garage' started by boggerless, Jun 4, 2003.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i purchased a 6 in. suspension lift for my 79 jimmy. it's BDS (formerly known as big dick suspension ).while driving around to get every thing to seat a little my brother hit a deep pot hole on the pasenger side and now it leans that way, i've lifted a few trucks with various brand lifts, and i know springs settle but damn allmost 2in. has any one else had this problem ? /forums/images/graemlins/k5.gif
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    That sounds like you broke some thing.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    id check to make sure you dont have any broke leafs or something messed up with the shackle...
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Those springs have a life time warranty, no questions asked.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    In what order did you tighen the bolts? if you sinched everything down while there was no weight on it, then you could have prelaoded the spring, and by hitting the pothole you caused that side to move. If nothing is broke(like your other post says) then I woudl loosen all the bolts up and start over.
    -Jeremy
  6. boggerless
    May 26, 2003
    22,728
    96
    thanks, i'll try that this weekend. all there was on the frame was the trans and transfer case when i installed the lift. as far as the order i tightened the bolts i don't know. i sat under the truck last sunday for 20 min. and couldn't see anything bent or broke. thanks again /forums/images/graemlins/truck.gif
  7. boggerless
    May 26, 2003
    22,728
    96
    well, i pulled it apart again. the bolts were loose on the drivers side. now it's 1in. diff. between sides. i say i'll hit a rock on the drivers side and nock it in place.
