BDS Suspension?
Discussion in 'The Garage' started by ncstate hale, Dec 9, 2002.
  1. ncstate hale
    ncstate hale Registered Member
    Nov 17, 2002
    7
    Raleigh, NC
    ok i am swapping out my 4" Rough Country front springs and rear blocks b.c my truck rides way too rough for my liking. Anybody know the spring rates on the BDS Glide Ride? what are your opinions of thier lifts? /forums/images/graemlins/thumb.gif
  2. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I saw that you go to state. I am a senior here at nc state. I just bought a 89 blazer, I was looking at bds suspension too, everything that I hear about them is good. Where do you go wheelin at? Where do you live at? Maybe we can get together and wheel sometime.
    Trey
  3. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    im in metcalf, im sure you have seen my K5 on campus, its the torch red with white top, 4" of lift and 33 BFG's, i havent found any good spots around raleigh, i was trying to get up with dawson444 so he could show me some of his spots, all ive found is construction site, but i really dont feel like getting the cops called on me /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif achuskies69 is my old name on here, but since i came to state i use ncstate hale, forgot i was signed in on this name /forums/images/graemlins/deal.gif
  4. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Yeah I have seen it. Mine is a blue and white 89. It is mostly stock because I have only had it about a month. I put a 2" body lift on it and rhino lined the inside. It was wrecked in the front, so I also did a bunch of body work on it. I plan on putting a 14bff and d60 under it next. Let me know whenever you go wheeling, me and some buddies went to uwharrie this past weekend. I didn't get to wheel for very long because my blazer was acting up. I was thinking of going again this weekend, let me know if you want to go.
    Trey
  5. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    I run the 5.5 BDS all-spring lift, and it rides a heck of a lot better than it did with a 4inch ProComp lift. It runs almost just as soft as it did with the stock suspension. BDS is the best bang for your buck suspension IMO. It also flexes great for an all spring set-up, I was able to rub the 37's in the rear DS fenderwell /forums/images/graemlins/eek.gif
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Hey Matt,
    Did you flip the overload springs on the rear of your K5? I am running the BDS 4" springs and the ORD 4" flip in the rear and it just doesn't seem to flex like it should. The rear spring pack is resting on the overloads just sitting there, so I thought about flipping it over.
  7. jay web
    jay web Registered Member
    Nov 9, 2000
    48
    n.c.
    hey guys, sorry to interrupt this post, but on the 5.5 bds lift- are drive shaft mods needed? i would think so but not sure
  8. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    DP--The overloads aren't flipped, though I have thought about it for better flex. For some reason the overloads like to more around a lot when I do flex, nothing serious just a half inch either way /forums/images/graemlins/confused.gif
    Jay Web-- Driveshaft mods will be needed, I had to too when I lifted it four inches, and deff. when I installed the 5.5 becasue I added the lift and 1 ton axles. Also to keep the vibes away, I had a CV joint installed on the rear Driveshaft
  9. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    BTW DP,
    It looks though you have great flex according to your aviator, is that pic with your 36's or 38's? I guess the overloads walk because there is no clamp on them, are clamps ever installed on overloads? The spring pin is at tight as I could get it when I installed the Zero-rates...hhhhhmmmmmm... /forums/images/graemlins/1zhelp.gif
  10. ncstate hale
    Nov 17, 2002
    7
    Raleigh, NC
    DP
    i saw your truck on the BDS website, how much money did you put into building those custom bumpers and rock sliders?
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Matt, I would check your u-bolts if your overloads are moving. The center pin really doesn't keep the spring pack tight, just together. The u-bolts should clamp those springs down hard enough that the overloads will not move. I think I torque mine to about 125 ft lbs. That picture is with the 36's. I noticed on some other pictures, I am getting a lot of body roll when the rear axle is flexing alone. That picture both the front and rear are flexing and kind of offsetting the body roll.
  12. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    ncstate,
    The materials I have in those bumpers probably doesn't total more than $300. However, I have a lot of blood and sweat in them, let alone time away from the wife and kiddo. Oh, I did have to buy a mig welder, tube bender, cut off saw, blah, blah, and blah. Lots of $ in tools...
  13. ncstate hale
    Nov 17, 2002
    7
    Raleigh, NC
    yeah just wondering about the cost, im using my truck as a daily driver/offroad vehicle, and i dont want to mangle sheet metal just yet, but the bumpers ive checked into are running 600.00 ea. at least. /forums/images/graemlins/angryfire.gif
