BDS to be higher than advertised?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85GMCJimmy, Jul 13, 2001.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    I have heard this a lot is this true? I have just bought a 2.5 lift kit from them with springs on all 4 corners.
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Higher in the front, lower in the rear.
    I hope you like the saggy butt look ?
    good luck
  3. 85GMCJimmy
    Feb 21, 2000
    83
    South Carolina
    I guess i will just buy some inch zero rates if it is really noticalbe, i will just have to see,
  4. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I know Mikey, 'Captncrunch' did the BDS springs and said the 5.5" springs were more like 6 or 6.5" after he put them in, and he is using the 0 rates also, so you might want to talk to him. He was very pleased with the springs though.
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I did a 4" BDS lift the same time CaptCrunch did, and I think it is a little over 5 inches (like 5 1/4"). I think even with some sag I'll still be over 4 1/2" I gotta 14 bolt in the rear (which is suppose to be 1" taller in the back unless you gotta D60 up front and it sits pretty level.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yeah I got some 5.5" BDS springs and they seemed almost like 6.5" initially. They have settled in quite nice and are about a 6" IMO. I'm currently running a 5" Superlift block [​IMG] until I can get rear springs and have 2 ORD zero rate add-a-leafs stacked in the back and it still sits a touch low. I'm betting one set will make your rear pretty good w/ springs all around. I love my BDS springs... the shocks are a whole nother story.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <blockquote><font size=1>In reply to:</font><hr>
    <hr></blockquote>
    yea, I gotta second that ont he shocks. I got the BDS shocks too, and they really bit. the lift really does ride good.
  8. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I shouldn't knock them too bad... just kinda like Rancho 5000's w/ BDS written on them. I plan on replacing them w/ either Trailmaster SSV's or Rancho 9000's soon.
    -Mikey
