Bead breaking
Discussion in 'The Garage' started by lochenjons, Apr 16, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I'm thinking I'm going to just dismount and mount my tires on my two new rims (got a 14b so 8 lug in the back now) myself instead of taking it somwhere. I've mounted tires before, a pain but possible. But last time I tried to break the bead of one of my old tires it would not come off. Any tricks or tools you recommend? Preferably tricks, I dont want to have to search around stores (I already have) or wait for somthing online
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    have another truck available? put a board on the tire right next to the bead area. Drive up it slowly with another vehicle, will do the trick. Make sure all the air is out first, of course.
  3. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,555
    1,473
    the armpit of the east coast, 08046
    take the stem out. lay the tire on its side under the rotor or drum with a board in between. slowly lower the jack so the onto the sidewall so the rotor/drum presses down on the board and tire.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just as Mr. Sled dog says. Easy job!
  5. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    I use a ramp, that you drive your car or truck onto to change oil, place the bottom of the end of the ramp onto the bead edge, slowly drive onto it, and poof, bead be gone! I've never had it not work. :)
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
  7. PDXCHVY
    PDXCHVY Registered Member
    May 18, 2005
    11
    PDX
    High Lift jack next to bead works really well also.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I made a simple tool for this. Weld a heavy washer, that fits over a lug stud, to short piece of chain. Make sure that you can still spin on the nut.
    Then make a lever tool with a foot on it. One end of the tool has a slot to capture a chhain link. The foot has a shape that fits on the tire against the wheel at the bead. The other end of the lever has a tube for the Hi-Lift Handle to slide over or into.
    Remove on wheel nut & install the chain. Place the lever w/ the Hi-Lift handle in place against the tire & hook up the chain. Push on the end of the jack handle. Takes longer to describe it than to do it.
  9. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Don't do this if you actually care about the wheel.
    If you have a really really really stuck bead (I parked my BACKHOE on the last tire I tried to debead... didn't work. Neither did pressing it with either of the buckets). Use a rosebud tip on a torch to warm up the wheel lip.
    Then use one of the jack/driving/backhoe techniques... pops right off.
  10. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    This seems like the easiest but wouldnt it just flip the tire and wheel on its side instead of keeping the wheel flat? iI've been meaning to get a highlift for awhile, once I do that will probably be my method of choice
  11. BlazerBud
    BlazerBud 1/2 ton status
    Jun 14, 2006
    473
    Chattanooga
    Walmart mounts and balances for about 7 bucks a piece with new stem.
  12. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Do you mean don't use the tool I described building? Why not?
  13. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    I think he meant his torch idea for really stuck beads
  14. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    1st- Go to Sams Club and get a membership.
    2nd- Buy as much food as you can fit in your rig.
    3rd- Force feed your wife/girrlfriend until shes fat as h*ll, but not so fat she can't fit through the garage door.
    4th- Duck for cover and have her fat *ss sit on the tire. When you hear the pop its off the bead.
    5th- Make her dismount the tires and do all the work; she'll be on her way to workin off the weight....
  15. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I have tire plyers. Works great, but I wouldnt use it on aluminum wheels.
  16. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I've used the Hi-Lift, just be careful...
  17. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Is this from experience??:haha:
  18. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    I tried this and it actually worked, barely. I was surprised how hard the bead held on. Then I tried it on another tire and it wouldn't work, I'm not sure why. I had to use the front of the truck because the rear was too light.
  19. mrdrinksalil
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Haha,
    Naw, anything over 125lbs is outa my weight class... lol.
    I will admit I have used my girlfriends 2006 Buick Randevous to drive up on my tires and break beads before.
  20. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    X2 but I don't use a board, just bare nekkid rotor on the tire (front axle).
