Bead locks
Discussion in 'The Garage' started by ssped, Mar 9, 2007.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    What is the better wheel to run bead locks on 16 or 16.5? which will hold the tire to the wheel better on the inside of the rim? or do you have to worry about that?
  2. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    16" will hold it better. It has the safety bead on the inside of the rim.
    Mike
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you are not running a double beadlock or an internal I would choose a 16 over the other with those 2 choices.
    Ira
  4. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    thanks. just needed spme input.
  5. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    If you are running a 16, do you really need a beadlock? With the safety bead ou should be pretty good to go as long as you keep double digit air pressure...
  6. sandawgk5
    Oct 28, 2003
    6,881
    Hey Ed I was running 8 in my tires out at Truckhaven and I do not have beadlocks. If 16s have the same internal setup as my 15s I do not see why 8 would not be possible for you.
    Ira
  7. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I was drooling over Max's swampers on the diesel. I am sold on geting a 60 in the front now. last Monday my truck was run into so I am trying to get some money out of them for the dammage:D .
