beadlocks on 16.5 wheels
Discussion in 'The Garage' started by K1Orion, Jan 29, 2004.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Who's got em?
    Anybody done the Rockstomper DIY locks or something similiar. Can I booger weld the rings onto my own wheels or should I leave it up to a "pro". Just gettin ideas here. /forums/images/graemlins/thumb.gif
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    If you can't do quality welding, leave it to a pro. That is the most important part. If your weld would fail your tire would most likely come off the rim, at high speed killing you or someone else. /forums/images/graemlins/peace.gif
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    TireLocs....
    If you're going to spend the money, you may as well get something that will secure the inner bead too.
    See my .sig for the TireLoc photo album.
  4. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    Who said anything about high speed? This thing does everything slowly. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    I'm a pretty competent welder. I was more interested in whether or not others have attempted it to see if it is worth it.
  5. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I make the DIY beadlocks and don't mind saying mine look much better than the Rockstompers, and if you can't weld and be proficient at it, you shouldn't do them yourself. Leave it to a pro. They don't take long so it probably wouldn't cost a lot of dough to get a welding shop to do it or if you know somebody who can weld, your in like flynn. Other than that, anybody can do them. If you have any more questions shoot me a pm. I'll be glad to help you with any questions you may have.
  6. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    Greg, I lookd tireloc's site, pretty cool idea.
    How do they perform? And of course, how much <font color="green"> $$$ </font> ?
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    They work like a champ.....
    I've run trails at 3psi no problemo (the inner bag stays at 25psi) They act like a "runflat" if you ever really shred a tire, and it takes less time to air up and down because you never touch the air inside the beadlocked area.
    Pretty ingenious. Roughly $200ea depending on size. JD Offroad sells them, but they are manufactured overseas, so the shipping delays can be a bummer....I think mine took about 8 weeks to get here.
  8. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    If your looking for a beadlock in 16.5 why not run Hummer wheels. They are double beadlock and you can get runflats. They look cool too. /forums/images/graemlins/thumb.gif
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Even if you are a novice welder (what I consider myself) it is very difficult to make an air tight weld, and even harder on a round surface for a full 360° and more than 52" long. I am working on my welding skills right now and pressure testing them also (I can get to about 45psi and then I find leaks /forums/images/graemlins/doah.gif)
    If you can do it they are the right price /forums/images/graemlins/waytogo.gif
  10. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Need info on both the Tirelocs {could not find the product at JD's Offroad} and where and how much a set of Hummer beadlocks would be.
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    From what I understand about Hummer wheels (not much)
    1. They weigh a TON
    2. They have a weird offset, so you need to spend more time re-welding them
    3. They weigh a TON
    4. They weigh a TON
    /forums/images/graemlins/smile.gif
    Everyone will have a favorite way to do things. Personally, I like being able to run a "normal" looking wheel and being able to beadlock it from the inside. I'm currently running a cheapy steel wheel now, but there's nothing stopping me from switching to a nice forged, lightweight aluminum wheel later on, and taking my beadlocks with me.
    BTW -&gt; http://www.tireloc.com/
  12. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I alwasy wondered this, if you switch wheels, wouldn't you have to unk the old ones beacus of the hole? Or would you put a bolt through it?
  13. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I suppose all it would take is a small coupon of metal on the inside of the rim, then a plug-weld from the outside to fuse it all back together. We're only talking about a 9/16" hole (or something like that) so I wouldn't worry about strength really......just an annoying air leak if it didn't seal completely.
  14. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah I was thinking mainly because Spickler was talking about those in a cafe in Denver with me once and and he has some pretty spendy aluminum wheels
  15. berg76
    Nov 4, 2002
    238
    St. Louis, Missouri
    The hummer beadlocks weigh only 42lbs. Thats maybe 15lbs more than a steel one. By the time you add your lock who knows what it will be. Not a big deal. The welding would be easier because it doesnt need to be air tight. I like hummers. /forums/images/graemlins/shocked.gif
  16. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I like hummers....
    Don't we all, but hey buddy this is a family site! /forums/images/graemlins/eek.gif
    BTW -&gt; The TireLoc is nothing more than a Kevlar insert and an innertube. There's no way I'll believe that any other beadlock system can be lighter.......
  17. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    at $200 a pop, not including the wheels, somethings gonna be lighter.
    YOUR WALLET!!!
  18. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    YOUR WALLET!!!
    Sure.....compared to NOT running beadlocks they're expensive. /forums/images/graemlins/rolleyes.gif
    Compared to any other double-beadlocked solution, I don't know how much of a "premium" you'd pay.... it just seems to me that nothing is "free". Hummer wheels need to be cut and re-welded for a normal offset OR you need to use the dually hubs to get them tucked under. Normal bolt-on beadlocks seem like a LOT of hassle (I'm remembering Chaz' stories about bolts breaking off every time he drove on the street) not to mention the hassle factor by the local police for running a wheel that's had 4 dozen holes drilled into it.
    Sometimes cool stuff costs money.... I wish it weren't true. /forums/images/graemlins/thinking.gif
  19. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    I inquired about tireloc , I believe last year and they did not carry for 16.5" at that time. Not sure about now
  20. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I'm not really looking for a double-beadlock. How often is a popped inner bead an issue anyway?
    Beadlocks aren't for a street driven truck. If its to the stage that its got beadlocks, its probably not a DD anymore. And why would you need beadlocks on the street anyway? and I'm not talking about driving a couple hours to get to a wheeling spot. I'm talkin about beadlocks on a DD.
    Come on, how many times have you seen a cop hasslin a guy cause he's got beadlocks? Not cause he was drivin like an a$$ and they gave em a hard time cause of the beadlocks to prove a point. Just cause he had beadlocks?
    Greg, the tirelocs are a cool solution, but I bought my 16.5 wheels before I know of their drawbacks. Now I am lookin for ideas to get functional beadlocks for minimal $$$. Rockstomper-esque add on beadlocks seem like an economical solution for me. $200 per corner for tirelocs doesn't. /forums/images/graemlins/tongue.gif
