Bear with me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Jul 14, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Ok, have a question. I don't have part #'s but it's pretty simple....... I have Rancho 9000's all the way around. They are for a 2-4 in lift. A friend gave me some rear 9000's for a 4-6" lift. I want to remove the old fronts and move the rear shocks to the front and put the bigger 9000 rear shocks on the back. I'm thinking this will give me more travel. Will the old rear 9000's work on the front? Or am I wasting time?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    the long ones, do they have the # 9012 stamped into the sides? how about your existing rear shocks? if so put 1 long 9012 on each corner.
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Both of the fronts I am removing say 9001 All 4 rears have 9112 on the side. The one set is a few inches longer than the other so they'll go in back. The old rears will go into the front.
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I'm not sure I'm understanding your question, but I can tell you that my truck (6'' lift)uses RS9112's at the very front (dual shock), RS9116's in the front (standard position), and RS9005's on the rear. Hope that helps you some /forums/images/icons/wink.gif
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    That answers it! Thanks guys /forums/images/icons/cool.gif
