Bearing clearance for th400 input in 205 case
Discussion in 'OffRoad Design' started by ponderingjunkman, Mar 4, 2002.
  1. ponderingjunkman
    ponderingjunkman Registered Member
    Dec 6, 2001
    14
    Cairo, NY
    Stephen, I just recieved the th400-np205 input gear and bearing. It arrived in good condition, Thanks!! As far as boring the case, the bearing should be a light press fit, correct? Am I correct in thinking it should be no more than .0005 bigger than the bearing? I lean toward making it a slight interferance fit to keep the bearing from spinning. Your thoughts?? Thanks again for the parts!
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You're pretty much right on, we usually find it to be a tight slip fit. Lots of wordy definitions for this stuff. Generally what we recommend is to measure the existing bearing and hole and use the same fit. 5/10ths over should be fine.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Can we send the t case to you to have this conversion completed ??
  4. ponderingjunkman
    Dec 6, 2001
    14
    Cairo, NY
    Hey Ramjet, I'm on the east coast- I could do the job for you and probably save you some shipping costs as well.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Local is typically cheaper because of shipping the 45 lb bare case around. We can do it here, charge for an exchange case is $90 and you'll get the case quick, if we bore yours we have to work it in and it's about $60.00.
