bearing failure? HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Nov 21, 2002.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    was up everybody. I have a weird noise coming from the front of my truck. It only happens when I have it in 4 wheel drive and have the hubs locked. It starts to vibrate and sound like a bad bearing. However when I unlock the hubs and leave it in 4 wheel drive the noise stops. Does this sound like a wheel bearing or something like a carrier or pinion bearing. Anybody had this problem. Thanks! /forums/images/graemlins/usaflag.gif
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    If it only does it in 4 wheel, then there is probably something wrong in the t-case
  3. 76K5
    Jun 23, 2001
    99
    North Carolina
    when I have the Tcase in 4 wheel drive and the hubs are unlocked it does not make the noise. So woiuldn't that mean its not in the Tcase? /forums/images/graemlins/usaflag.gif
  4. Calclips
    Apr 4, 2001
    1,005
    I'm sorry, I read wrong. You said that it dosen't do it when you have it in 4 wheel with the hubs unlocked, that would mean that it would probably be a problem somewhere in the front axle.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Most likely a steering u-joint in the front axle.
  6. Grim-Reaper
    7,385
    Atlanta
    Ujoints in the axle shafts or the driveshaft. If you get a vibration under acceleration I would start looking at driveshaft.
