Bearing or Bushing What is Better?
Discussion in 'The Garage' started by DuallyK5, May 30, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    What is better and will last longer a a Sm465 Input shaft. The bearing or the brass buhsing? I use this truck in the woods alot so what would last the longest? And how would i get the bearing out it i needed to.
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I would take a bearing over a bushing in almost all cases.
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Bushing all the way, less to break, it is just a piece of brass...
  4. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Bushing, especially if you run mud.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    or any form of dirt. sand, gravel, mud, hell even in the rocks a bearing is a bad idea. for a street only vehicle, you *might* be able to get away with it.
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Weather it's a bearing or a bushing, they are usally no fun to get out.
    I made my own special tool for it. The hydrualic method works, sometimes, sometimes not though. The tool works 100% of the time. At lease on trucks, it's too big for smaller clutches in cars etc...
    The tool is just a small 1/8" thick piece of metal with a drilled and tapped hole in the center, I slip that in behind the bearing/bushing and then take a grade 8 bolt and stab the hole I tapped. The pieces straightens up and just barely has enough edge at that point to grab the back of the bearing and thenjust turn the bolt it bottoms out and pulls out the bearing. Works everytime. The trick was to get a piece of metal small enough so you could fit it through the hole and get it behind the bearing, but big enough that when it straightens out it grabs the back of the bearing.
  7. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    Bushing. I have heard of bearings failing or falling apart and then you loose the support for the shaft and bad things happen. A bushing will wear slowly but wont fail.
  8. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    ive always ran the bushing never had a problem
