bearing press / puller (for carrier bearings and pinion bearings)
Discussion in 'The Garage' started by TX Mudder, Nov 7, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I've been searching online without luck.
    I don't need big heavy duty ones, just enough to get the job done.
    I'd rather just buy the tools if it is not too expensive vs. paying the shop to press and pull for me.
    -- Mike
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've done diff bearings with my $99 Harbor Freight 12-ton hydraulic press. To press them on, I just use a short piece of iron pipe, with a pipe cap on one end for the press to push on. To get them off I had to go rent a big-a$$ Snap-On bearing splitter. I think it had a 5 inch jaw. Smaller ones wouldn't work on the pinion bearing, they would hit the bearing cage before they would grab the inner race. Snap-On gets around $150 for the splitter, so $10 to rent it for the day seemed rather cheap. /forums/images/graemlins/wink.gif
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I pulled my bearing using a regular 2 jaw puller, gonna have to get them pressed on though. I have pics of the pulling process, i will see about uploading some here in a bit.
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I searched on Harbor Frieght without luck.
    IS yours something like this one: web page ?
    It looks like a good deal at $111.00 with free shipping (it's over 100 pounds!)
    -- Mike
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Wait, i found the Harbor Frieght one.
    Shop Press
    It comes with the arbor plates, which I frankly don't know what they're for, but it can't be a bad thing.
    -- Mike
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i did mine with a big hammer to get mine off, no j\k. i did that only because im gunna put my ring and pinoin off my 10 bolt on the wall in the garage, as a momento to when i blew the gov-loc in my truck, and when i put the 12 bolt axle under it.
  7. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    here are some pics of removing the bearings, this part was pretty easy. Getting them on...well my friend said he could get them done for me for $10, probably will just go that route
    pic 1
    pic 2
  8. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Randy's Ring and Pinion sells a puller kit that is made for side bearings and pinion bearings. I think it is about $250 or so. I bought a Snap On puller set for side bearings that was about $200, it is part of their "beam type interchangeable" puller line. The nice thing about the Snap On is that you can keep buying different jaws etc. for different puller jobs in the future. The set from Randy's would be by far the easiest one to use at home on differential parts. Fortunately, we have the bearing separators and a good press here where I work.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Mine is the 2nd link you came up with. Order their catalog and you'll start getting a new sale flyer about every other week. They have stuff on sale all the time, including the presses. /forums/images/graemlins/cool.gif
    The arbor plates are thick chunks of steel with various size and shape notches cut in the 4 edges. You place then on the crossbar to hold the part that you're trying to press something out of, and the notches leave a hole for the part actually being pressed out to pass through. /forums/images/graemlins/cool.gif The press isn't the most-used tool in the garage, but when I really need it, it sure beats driving to a shop and paying $10-20 to have someone else do the job. /forums/images/graemlins/thumb.gif
    I've used mine for bearings, removing/installing wheel studs, removing/installing A-arm bushings and leaf spring bushings. The only problem with the 12-ton is that the frame is pretty narrow. One of the larger ones, with a wider frame, would make it easier to use. Some parts are too big to sit on the crossbar, so I have to balance them off the edge while trying to setup the press. /forums/images/graemlins/frown.gif
  11. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    A 2 jaw puller to remove them works good.....To put the new ones on put the diff in the freezer and the bearing in the oven at about 250. Then use a peice of thicker walled pipe the right size and tap them on. They slide on pretty easy after heating the bearings.
    Brian
    82 burb
    40" TSL's D60/14FF SM465/np205
  12. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    At work I use a air hammer with caution to take the bearings out and to put them I use are snap on press.
    Colin
