Bearing Press????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Jan 2, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Can anyone recomend the type of bearing press I would need to use on a differential bearings??
    If i'm thinking correctly then the style needed looks like one of thoes stand up deals with a bottle jack mounted to it?? Is it??
    If so does anyone make a 'bench top' style press that would work for diff bearings and ball joiints???
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  2. Channing74
    Channing74 Registered Member
    Dec 14, 2000
    77
    Southwest louisiana
    We have the stand alone type at the shop and it works pretty good ...... if you know somebody good at fabbing you can make one fairly cheap.....
    Bigger is Better [​IMG]
    Channing74
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I used a 120$ 12 ton version from Harbour Freight. I needed to get a bigger set of arbor plates than what came with it- they were too cheesy. If you can swing the money, Grainger sells a sweet 16 ton Dayton. Forget the bench top ones with the linear gear- not powerful enough. My .02....
  4. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    i would say get the one from harbor freight... iwas going to get one a while back but funds got low,,gonna get more soon!! i bought some other stuff from them and was pretty happy with it..it's not the biggest or the baddest but for us lamen,homeowners it's pretty good to start out with..:)
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  5. Burt4x4
    6,854
    Ya thats what I was thinking!
    So what do the plates do?? I assume it's for between your work and the press plate???
    Any more thoughts on the style to get or specialty pieces that will make the job smoother???
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    That's right, the plates support whatever it is you are pushing on. If they aren't set right on the press, and you start crankin....KA..POW...Watch out for flying parts[​IMG]. You will need to pick up a big bearing splitter as well for the pinion work.
