Bearings & Seals???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gpd4, Jan 21, 2002.
  1. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    How can I tell which bearings and seals are in the rear end of my 85 without taking it apart? Every part store I've been to has told me that there are three or four different sets that will fit in the 12 bolt rear end. I'd really rather have the parts on hand when I start this project. Any help would be greatly appreciated. Thanks.
    '85 Blazer... 9" lift... 35-12.50 BFG AT's...LOTS of rust
  2. gpd4
    Jun 25, 2001
    55
    St. Louis, MO
    If I pull an axle and get the seal number, will that give me enough info to get the bearing numbers?
  3. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Try the dealer. They use your vin for parts. It's worth a try.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Unless you swapped the rear end it should be a 10 bolt in an 85.
    My Chevy isn't broken, its just out of gas.
  5. gpd4
    Jun 25, 2001
    55
    St. Louis, MO
    It's definately a 12 bolt rear end. I had it "rebuilt" last year when the pinion fell in and threw the drive shaft and all that. I don't think I got anything more than a new ring and pinion. The bearings lasted about 10 months after the rebuild, and the lube seems a bit metallic these days. I've been putting this off for too long, and it's starting to whine a little louder these days. It looks like I'm going to have to dive into this blind and get the numbers from the source. Too bad it's been so cold here...it won't fit in the garage!
