beat to death- is 14bff necessary?
Discussion in 'The Garage' started by XHitman396, Feb 22, 2005.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    '87 k5, mild motor, built 700-r4, no rocks, pretty much all mud, so i need the clearance of a sf if possible, daily driver. 35" tires with 4.56 or 4.10 gears. can a 14bff be trimmed enough to not make much of a difference in clearance in the two without taking an entire bolt out? am i gonna really need the extra strength in th ff? then there's the adapter part of it, money is of the essence.. thanks for your input...
  2. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    dont for get the little brother 9.5 sf 14 bolt.
  3. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I'm putting a 14b SF under mine in a little while (it's in the driveway now, but I'm waiting until I can afford new wheels and tires...). I think for mud, the SF is definitely going to hold up with what you're running.
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Large axles are worth it for the peace of mind, and it's not like you're putting a FW60 in a Jeep, it's dead simple
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I am going to put a F**d 9" under my blazer 36s SF 14b are expensive around here will have to buy adaptors to run the 6 lug wheels though :rotfl::rotfl:
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    The reason I put a 14BFF on mine was because the C-clip failed on my 12B and when I made the turn to go down my street the wheel and axle shaft flew out the side. I could just imagine what that would have been like in traffic. Now I won't have to worry about that dangerous piece of engineering any more and I have a stronger axle to boot.
  7. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    how is the D60's ground clearance , it is similar to 14SF maybe?
    like spearchucker said it is worth getting rid of those c-clips
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    with 35's and 14bff you will have horrible clearance even if you shave it.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mild truck , just get a lockright and some spare shafts . Save your money for recovery stuff for when you are stuck in that mud :D
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Advantage of the 14bff is that you only do it once. It is not to likely you will have to replace an axle shaft or anything else in it. They are also easy to put detroits into and disc brakes swaps are pretty easy/cheap.
    The clearance issue isn't as big of a deal in mud as it is in rocks. Just shave it as much as possible.
    If the 14bsf wasn't a c-clip design it would be a much more appealing.
    But thats just my opinion, if you want a worry free axle that will last a long time and be easy to upgrade, go 14bff...also good if you go to bigger tires, and everyone gets that bug eventually.
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Well, I like the 14 bolt FF because they are strong, and they are cheap. I am more into mudding and trails then anything else, so the 14 bolt FF fit my needs well. Guess it doesn't matter anymore, I sold the 76.
  12. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i ran a 14bsf for about a year untill the pinion bearing blew up, then i put a ff in
  13. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll 2nd that!!:waytogo: :waytogo:
