beautiful
Discussion in 'The Lounge' started by 84gmcjimmy, Mar 6, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'm happy.
    Today is was +14* CELSIUS outside. it was soo warm
    I finally burned a big pile of scrap wood...accidently though.
    I poured some oil on it, and then I lit the oil on fire (hopeing to burn the oil so the deer dont lick it) and I guess I had too much...come back 5 minutes later and the whole pile is blazin' with flames. Kind of panicked because I didn't have water, and there was dry grass all around the fire...
    So half an hour later of scrabbling around I got water...hooked it up to the only running tap outside (other ones aren't working for some odd reason) and ran 100+ feet of hose to the fire and wet the grass.
    But back on topic, it was gorgeous outside. I went out at 6:00 tonight to check the woodstove...in a t-shirt and...SHORTS! its amazing.
    It must be spring almost.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah, it'svery nice here too. Today thoguh, there was a bad dust storm because my resteraunt is right next to a grain bin yard. I had to do a tactical gunfight run to the door. I was under a waitresses car trying to lock my dars with the car remote.
    Yeah, fires can be scary. I dropped my gas tank when putting in the van tank, and gas went everywhere. I ran out of there post haste and called my friend.
    Spend a bit of time outside watching the clouds, it's soulfull
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea it was almost 40 here, still alot of snow still on the ground and the ground was still frozen. i still had to wear a coat because i was laying under my truck in water that ran under it when the snow melted off the truck.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    hopefully the taps that arent working, arent workin cause they are frozen up. Might cause issues, but Im no plumber.
  5. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    it was 60 degrees here. Nice to see descent weather for a change. I'm still getting used to this snow crap. Don't have that in Texas.
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    felt nice here till I went to the carwash. No matter where I was, the wind blew the water on me. 40 degrees and 10mph wind=co0lllldddd!:(
  7. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    60 down here on the eastern slope, nice and toasty.
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    hopefully they aren't frozen up! :(
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Man, mine freeze up once in a while, I've had to take pure hot water showers, I'm glad my waterheater isn't set too high.
    Come out bright frigging read and lightheaded
  10. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    I could set my 440 Dodge on fire and warm it up a little here!!!!
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Nice day here from what I could tell looking out the bay doors! Twelve and a half hours at work today and yesturday and Friday.............Off tomorrow though!! Gonna try to do a little maintenance on the '75 getting ready for the ECBB 05. Bunch of little things and several big ones in the works. Heh heh..I said
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    You know if you push the remote into the bottom of your chin it extends the range by a good amount:D
    Im serious go try it
  13. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    69 degrees and sunny, I <3 TEXAS. :D :xmas:
  14. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Same here in La. High sixties and sunny. Also known as winter.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    was 50* last night at about 11:30, its fuggin cold out there today though!
  16. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    60's and sunny here today, it made me sick to sit at my desk.
