bed length?
Discussion in 'The Garage' started by CenTxk5blazer, Oct 25, 2005.
  1. CenTxk5blazer
    CenTxk5blazer Registered Member
    Oct 19, 2002
    90
    Fort Worth, Texas
    I need to know which points on the frame to measure from so that I can determine the bed length? The truck is a 94 chevy 1-ton that currently has a western hauler bed. Thanks for the help.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    do the wheel base. this is best as some are cab chassie and thay moved the axle on some. the axle might be in the wrong place if you put on a box.
    center of front tire like the spindle to center of the rear will get you wheel base spec. post up and we will help ya.
  3. CenTxk5blazer
    Oct 19, 2002
    90
    Fort Worth, Texas
    From what I can tell the wheel base is about 135-136"s after several measurements. According to the vin, the truck was a cab and chassie.
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    sounds vary close to stock long bed specs. but cant remember off the top of my head.
  5. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    Id like to get my hands on those 80's wreckers and cab/chassis and put a long bed on there. They are sweet because the 14ff is narrow and the dually fits under the stock bed for a trick look. The wheelbase is 3" longer than a stock 8' bed so you need to cut up two beds and do a little weld/bondo work to make it look stock. When they are done they look sweet though!
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    sounds like a cool idea, got any pics of this done?
  7. CenTxk5blazer
    Oct 19, 2002
    90
    Fort Worth, Texas
    So will a stock 8' bed fit on the chassie w/o mods? If so then the gap between the cab and bed will just be wider??
  8. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    I dont have pics but I will try to get some tomorrow. A friend of mine here in portland CT did this and his truck is very nice and very tuff. The bed will fit and yes the space between the cab and bed will be 3 inches wider.
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The frame shape is really quite different between the pickup and C&C. It wouldn't surprise me if the bed and cab end up at different heights :eek1:
    Check out the frame diagram at the bottom:
    http://brochures.slosh.com/1991/comm09.jpg
    EDIT: Note the axle widths also... looks like the C&C axle might be wider than in the 73-87 trucks.
