bed liner
Discussion in 'The Garage' started by Bhintz, May 28, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    anybody ever use or heard of Dupli-Color truck bed coating, Im going to put some liner down in the back of the K5 and I bought this stuff and was wondering if its good or just some knock off P.O.S.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Thats what Ive got on the inside of the cab of my truck. I like it and it has held up fine so far.(A little over a year)
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Make sure to make the superface super clean. And put 2 or 3 coats.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Do a search, it's been hashed over many a time, but it all boils down to prep work! /forums/images/graemlins/thumb.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Search. Duplicolor, Herculiner, "bed liner" etc. This has been discussed at length on several threads. Comes up about once every month or two...
  6. outlaw612
    Feb 11, 2001
    2,342
    2 or 3 coats??? I used almost 2 gallons in the cab of my truck alone! /forums/images/graemlins/thumb.gif I usually go overboard.
  7. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    at first i did 2 coats with 1 gallon but some scratched off when i loaded my aXLES in there. I went back and put another 2 coats with another gallon and its been shady ever since.
  8. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    just removed all my carpet and found 2 big rust patches /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif this happen to you, how did you get it out, and the carpet over the fenders sucked to get off took a little over 2 hours to get glue off /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif about to put on liner Ill till you how that goes, it cant get any worse I hope knock on wood /forums/images/graemlins/thumb.gif
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I wouldn't use duplicolor, I haven't had any luck with it. Herculiner seems to be ok for off the shelf liners, if you do use the duplicolor, DON'T use the spray cans. that stuff flakes off faster than a sorority girl at a frat party. Either way, do a LOT of prep work, when you think you've done enough prep work, do that much again.
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    TXsizeK5 What did you use DUPLICOLOR?
