Bedliner - Front Bumper?
Discussion in 'The Garage' started by Ben B., Nov 6, 2005.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    I don't have the money or will power to get aftermarket bumpers, so i'm thinking about applying bedliner to my front and rear bumpers.
    Will the bedliner go onto the bumpers and if it does will it make them any stronger?
    Also how do I go about mounting D Ring Shackles to my stock bumper?
    Any pics would be appreciated. Thanks.
  2. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    You have to scuff up and I suggest primer first. and it will not really add any strength to it, unfortunately.
  3. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I bedlined my front bumper. Just scuff it up really good. I used a combination of 60 grit sandpaper and an abrasive wheel on my drill. And I sanded until it wasn't shiny anymore.
  4. BudTX
    BudTX Registered Member
    Oct 4, 2005
    36
    Kansas
    I know a guy that Line-Xed his Ranchhand front bumper. It did not add any strength, but looked great and bugs did not stick to it.
    If you want secure recovery points in the front, you need to attach mounts for D-Rings to the frame, not the stock bumper. That will require some fabrication work, but can be done.
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    If you mean a professionally sprayed liner (Line-X, Rhino etc) it would probably cost about the same as the steel for a real bumper would...
    Sure, scuff them first though.
    Not in any way relevant to a bumper. Spraying a whole tub would probably make the structure of the tub a bit more rigid... but with something like a bumper it wouldn't make enough of a difference to be relevant.
    Don't, unless you want to die young. Stock bumpers are way to flimsy to mount any recovery points too. Atleast... the ones on my 85 were...
    j
  6. MrArmyAnt
    Dec 29, 2004
    662
    Apparently He speaks from experience ^. You have air compressor/hopper? if not get the spray cans at autozone, it holds up ok, just not nearly as good as the real stuff.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    This is sound advice. The POS bumper will NOT withstand anything more than a light tug. By hand, not another truck. Post up pics if you spray the bumper - I'm interested in what it looks like.
