bedliner in the cab?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Apr 11, 2001.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    I know someone's done this...how do you like it...any reason this would be a bad idea??? Anyone??
  2. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I have Line-x spray in bed liner in my k5 and love it it is easy to clean it look really cool and it stops rust
    I have some pics at my photo alubm
    http://www.trailblazer90.coloradok5.com
  3. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I really like the way that line x spray looks on your truck. how did you do it. did you just spray it on the existing plastic moldings? i am on the verge of redoing my interior and i lilke the bedliner. i might try it. now i just have to find a color to paint the metal i guess.
  4. zach78k5
    May 14, 2000
    406
    where did you get the diamond plate on the doors. it looks very good. let me know. thanks
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'd like to spray the inside of my hardtop for more sound proofing, and also for a greater insulation factor...
    Has anybody tried this, and if so how did you like it?
    Thanks,
    Jeff
  6. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Did you spray the liner yourself? If so, where can I buy it . How was it sprayed, I assume the panels were removed to be sprayed? I like the aluminum panels.
  7. James90
    May 18, 2000
    986
    Rocky Mount NC
    Line-x is done by a pro what I did was take every thing out of my blazer and take it to Rolling K line-x when I took all the trim and door panls out I cleaned them and skuffed them up and then had them sprayed
    the Diamond plate on the door I got form a frind who owns a fab shop and cut it with a 4.5" grinder
    the line-x cost me 600.00 to get the whole in side done but that is every thing there and the stuff has a life time warnty
    [​IMG]If you want to run cool
    you got to run on Heavy Heavy Fuel
    <A target="_blank" HREF=http://www.trailblazer90.coloradok5.com>http://www.trailblazer90.coloradok5.com</A>
  8. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I just did the inside of my cab over the weekend with herculiner. It took one can and I did the cab and lower portion of the doors. I ended up losing about an eighth maybe a little less that that, because I didnt' seal the can right when I was done, but it worked gread and I have no complaints so far. Right now you can get free platinum sparkplugs with purchase of herculiner kit &lt;$100&gt; check out <A target="_blank" HREF=http://www.herculiner.com>http://www.herculiner.com</A> for details. The kit is what I used, comes with just about everything you need, you should buy plenty of gloves :) it does stick to hands quick.
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I had the inside of my Jimmy done with Rhino Liner about three years ago. It is holding up good. My only complaint was the first coat was too thin in the cab floor area. They redid that and the texture ended up being a little different. As far as the actual product, I am very happy. It is so much easer to clean than carpet, it is even better than the rubber mat I had in my 78.
    When I had it done I removed everything inside. It is coated from the firewall to the tailgate. If you leave the top off for any length of time it will make your life much easier. The one thing I would change if I were to do it over is to add drain holes & plugs before I had it sprayed.
    There are pics of mine on the "Custom Storage" page of my site.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  10. James90
    May 18, 2000
    986
    Rocky Mount NC
    Zach
    I sent you an E-mail tell me if you dont get it I am not that good at all this pc stuff!
  11. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Used Herculiner in mine after fixing some rust holes. I covered from the firewall to the tailgate, then up the tailgate. Did it last fall and it's holding fine. Costs around $100. Like AGM says get lots of gloves. The stuff sticks to everything, and doesn't want to come off. Also get a fan or 5 to vent out the truck (even if you're outside). You'll feel all sorts of fluffy if you hang around the fumes too long.
    Why do people keep calling it a Bronco!!!!!
