Bedliner on outside of k5?
Discussion in 'The Garage' started by JUNIOR-K5, Jul 22, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Thinking of putting bedliner on exterior of k5. I want to put it from center bodyline down on my 80 k5. Was wondering which one you guys recomend durabank,herc.liner etc. Also do I have to sand down the paint or can I put it over. Thanks
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Some of the bedliners fade in the sun (herc for one), so look into that if it will make a difference for you. Most do not require sanding, but good prep work will make the bed liner adhere better, resulting in a better quality job. I would at least clean and rough the surface with a scotch brite pad.
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I thought durabank made liner just for painting the outside that wouldnt fade but dont know for sure.
  4. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I've been thinking of doing the same. Durabak has a UV protectant in it,so they say it resists fading.
  5. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I've got a buddy who's into the heeps. Alot of the guys that run cherokees will paint the lower sections of their bodies with bedliner. I was considering doing the same. If nothing else, I'll paint the inner wheel wells and probably the undercarriage.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Just don't put it on anything that you mightwant to weld or anything like the axles. It is PITA to get off to weld and it will chip and lift allowing for rust.
  7. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    I would suggest Durabak. They make a coating w/out texture. http://http://www.durabakcompany.com/smooth-durabak.htm I am going to use this product when I finish my body work this fall.
    There are a few member that have done this, but I can't think of names right now...brainfart!:thinking:
