Bedliner on the Roof
Discussion in 'The Garage' started by tx_sub, Apr 19, 2006.
  1. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    The paint on my roof is bad, and dirty. For those of you who have lined the exteriors of your rigs, does it make your interior hotter in the sun? I realize some of it is color dependent. I have a burb and the large surface area to heat up the inside.
    Cheers
  2. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    I dont think it makes it hotter. It may even insulate it a little.Just dont do black thats asking for the heat--Eric
  3. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    I'm entertaining black, blue or gray, or any combination of the above. I know that blue can get hot due to its frequency in the light spectrum. I have the light blue, I think its called French Blue. I still want my burb to look good at 20 feet.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Do it and post up the results. I have been thinking about doing the same thing.
  5. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I did it to my Burb, used black and didn't notice any difference in temperature. It worked out really well, I was climbing on the roof daily with the kayaks and almost slipped off once because of the water. I used the brush on do it yourself, I love the stuff easy, durable and cheap.
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    midnitewarya has painted his hole rig with rhinoliner and he said he has regretted it form the day he did it.
  7. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Teh top of my truck has bed liner on it. I didn't do it, and it looks fine, but my guess is it just made the top heavier.
  8. Orange Crush
    Mar 6, 2003
    440
    You dont want to line it if you ever think you might be welding on it. My rig is sprayed inside and out with speedliner. I wouldnt do it again. Well maybe the inside but not the outside.
  9. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I did the outside of mine. Didn't seem any hotter, but not long after that I got a soft top which I mostly run with now. I save the hard top for winter ski trips out of town.
    The soft top is a heck of a lot hotter than anything you'd put on the hard top.
    I like the stuff on the exterior. There are some concessions (it tends to oxidize, even with a UV protectant, and you have to scrub it with a scrub brush to clean it, but it is such a durable surface, I think it makes up for it.
    Good point about the welding tho.
  10. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    You happen to know what brand it was? This is exactly what I want to do.
  11. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Dont get white, my buddy lineX his ramcharger top white and less than a year later it looks puke greenish brown and very ugly. They do fade considerably. No chips or scratches and looks profess except the color fade.
  12. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    Fireplug, do you have any pics you could share?
    Would an angle grinder, wire wheel and some patience get the liner off if you really needed bare metal?
    Skigirl, I like the color you have. You mixed blue, black and red right? How has it faded compared to black, if you have anything to compare to? I just want to do the top, so it won't be seen by anyone other than truckers and other big trucks.
  13. Skigirl
    Apr 2, 2001
    2,563
    Yes, I mixed blue, black and a little red. Interestingly enough, the black hasn't faded hardly at all. The blue fades more than I'd like. The good part is that I can remove most of the oxidation with a scrub brush. Bad news is I can't remove it all (on the blue). So in parts it looks a little lighter than it used to. It's easy enough to do a new coat on it when it exceeds my tolerance level
  14. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    Did you use the UV additive in the black? And tell me again the brand you used.
    Thanks for the response.
  15. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I seem to have lost the pics I had, I'll grab some more tomorrow, and post in the evening.
    I used a product called Hippo (hmmm where'd they come up with that?), but if I'm not mistaken it is a Canadian product so I don't know if you would be able to find it down there.
    It is an incredible product though. $50 bucks or even less, for a p/u bed. And it is very durable, I've used it a lot inside and out and the only scratch I got was from a TH400 bouncing around in the back for a couple of weeks.
    Oh and to answer the question about getting it off with a grinder...yeah probably, but it wouldn't be fun. If you are talking about small areas for welding repairs then yes no prob, but to revert to regular paint...YIKES.
  16. Skigirl
    Apr 2, 2001
    2,563
    All product was Durabak and all UV version. IIRC they call it (color)-18. 18 indicates the UV version.
  17. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    To take the stuff off take a razr make some cuts that are like a strip, peel it up and peel it back slowly.
  18. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    My Blazer has Rhino on the roof of the cab only. I bought it from PO like this. I like it alot. It eliminates worrying about the drip rails rusting out... I don't have to be as particular about washing all the way up there...and I think it softens the road noise a bit since I don't use a headliner. It is black, but so is the entire rest of the truck, so I don't know about heat. The Rhino dealer sells stuff to treat and restore color too, if you ever get concerned about it fading.
  19. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Here's some pics. Not the best as they were taken at night. The 'dots' you see on the roof are raindrops.
    I've used the bedliner inside, the roof, the hood, and on my Blazer I did the mirrors.
  20. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    That looks nice. I especially like the leading edge of the hood.
