Bedside Protection
Discussion in 'The Garage' started by Hossbaby50, Jan 28, 2005.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I just want to let everyone know and see a prototype of a new rear bedside protection for K5's. A local offroad shop made the set for me. The hope is that they will help protect the sheetmetal from light hits on rocks and moderate dragging on rocks. I am going to test it out this weekend for the first time. I just got done installing with the help of Matt (az-k5). The install if very easy and looks pretty good in my opinion.
    The material is 1/4" thick HDPE (high density polyethelene). It pop rivets onto your stock sheetmetal. It is form fitted for K5's. HDPE is a plastic material that is supposed to be self lubricating and pretty durable. The panels are very light to help keep they weight of the truck down. Both panels weigh in together at around 10lbs.
    Here are some pics
    Before:
    Panel:
    After:
    I think they will definilty help with light hits on the sheetmetal and help dragging the sheetmetal. I haven't had time to finish all the pop riveting yet. There are still more rivets to be installed. You can get the idea from the pics though. I ran out of rivets otherwise I would have finished tonight. The worst it did for me is made my truck look a little nicer not having the scrapes and side dents showing.
    I would like feedback on if you like it, don't like it, are interested, whatever. What do you guys think?:ears:
    Harley
  2. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I like the protection but the pop rivoting throws me off. without the polyethalene or whatever the hell it's called, you can fix your body with a drill, a slide hammer, a suction cup, bondo, and a welder.
    I guess you could take it off and weld up the rivot wholes sand them down then get some bondo but it just makes more work for the body repairs.
    I would definetly consider it with damaged quarter panels or fenders but on a clean body i wouldn't drill 40 holes to put some added protection on that won't stop the metal from bending. The plastic gives as much or more than metal. It does protect against scrathes though.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think it'll work great. We have that stuff at my work on our machines to keep boxes sliding while they go down a conveyor.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I saw the title of the post and thought it was going to be about a .45 you keep under your pillow!:grin:
    They look good to me and would stop 'dragging' but can't help but think that those pop rivets will pick up preety bad on rocks and just tear the lot off:(
  5. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    How about double sided tape? If it adheres to this stuff ok it would prevent the pop rivet look and allow you to take it off for repairs if necessary.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I would have the same concern as above about the poprivets. Wont those be pulled out/loose if they contact anything solid (rock)?
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    :waytogo: :waytogo: :waytogo:
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The pop rivets are countersunk into the panels so they are flush with the panel. Doublesided tape would not hold the weight if you drug the panel on objects. The pop rivets should help disperse the weight of hits on the panels over a larger area to help prevent more damage to the panel.
    If you bust a few pop rivets you can always put them back in. They are pretty cheap and easy to use. The other reason double sided tape won't work is because Polyethelene is VERY slick. Not much will actualy stick to it. I used 3M weatherstrip advesive to help seal out water from getting behind the panels and it didn't want to stick very well. It is supposed to be one of the stickiest adhesives available too.
    The reason I went for the body protection panels instead of bodywork to fix my damage is because this truck would just see more offroading that would damage the redone body work. This mod will hopefully protect the sheetmetalf from further damage and is replacable if the panels get to beat up. This truck sees some pretty heavy offroad action so I want to try and prevent body damage instead of fix it.
    To get rid of the pop rivet look (which I kinda like) you could color the pop rivet heads black or use some other means to blend them in with the panel.
    This mod is also alot cheaper and easier then body work anyway.
    Harley
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, I've come across some of these newer meterials at work and they are pretty slick. Didn't realize they were countersunk. Sounds good.:grin:
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I like , I know they can do colors if they chose , if they eventually have white/tan I would want in asap :D
  11. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
  12. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It isn't designed for that "super clean perfect truck" look. It is made to take moderate hits (more than the steel) and keep a dent free apearance. It also slides on rocks better. It is more for those that actually wheel but still want a cleaner truck. In AZ you don't have time to do bondo and body work after every trail. We wheel every other weekend in the fall, winter, spring, and bondo/paint is hard to do on a metal surface when it is 100°+ outside in the shade. It is not a stop all for dents but works great for the normal "trail oops" This is the same stuff most of the comp buggies run for skins. I was really impressed with it my self.
  13. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Since each panel is only 5 lbs, I'd consider bonding flexible magnetic backing plates instead to these panels, so it is easily removable from the body. I've made my own before, it worked pretty well. (the magnet, not the plastic)
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i think that would probably be the issue... most products like that are near impossible to glue anything to.. we uses lots of similiar products on the boats... starboard, etc... and although awesome in some charachteristics, adhesion is usually not one.. mechanical fastening is the norm usually...
  15. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    This is not for protecting the paint. It is to keep small dents, heavy scrapes and gouges from forming. You can lay a good 20% of your rigs weight on it and they will hold up just fine. It is for protecting where armor cant. It is not to avoid pinstriping and stupid minor things like that. It allows you to go into a trail with a nicer rig and not come out like this as easily.
  16. RustyMule
    RustyMule Registered Member
    Dec 18, 2004
    73
    Westford, MA
    How much $?
  17. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I think you would lose a lot of it's ability to protect the bedsides if it was simply held on by magnets or double-sided tape. Besides, even a light hit would most likely just peel the panel off.
    The fact that it is solidly riveted to the stock sheetmetal means that the overall strength will be much greater........the strength of the stock sides and the new panels are basically combined into one piece.
    Overall the I like the idea. Keep us informed on how it works out.
  18. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Interesting alternative to going the beefy route (diamond plate). Ive never thought of this before but it makes sense, hmmm, this could catch on :waytogo:
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The mor eI look at it and the more I look at my white panel , it would look tough with a black one on it . Do they need any more testers :whistle:
  20. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was told pricing will be in the ballpark of the $160-180 range for the panels like mine. I believe that they are going to have the option to go lower down the B pillar and also wrap around the taillight some to protect it. This may cost a little bit more but I don't know for sure.
    The makers of this setup is www.simplyoffroad.com
    I am going to test them out this weekend.
    Harley
