Beefing up a ten bolt?
Discussion in 'The Garage' started by johnathan, Apr 10, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I know....I know.... Dana 60....Right now I just can't afford that.What are the weak links of the 10 bolt?Should I go with some beefier axles or just some beefier u-joints?I'll be throwing a lock-rite in there....maybe leave it open to keep it alive:crazy:
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    :waytogo:
  3. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    I can't in good conscience recommend that you spend any money on a 10 bolt. That said, I did and it had a pretty good run, but it is no longer in my truck and I didn't get anywhere near my investment back when I sold it (I went D60). I say get some good spicer joints (760X) and carry spare joints and shafts. Junkyard parts only, if you spend a bunch you'll regret it later. If you're running a big tire, leave it open or at most go with a limited slip. Mine had a TrueTrac and it went remarkably well, and stood up to my (at the time) 35x15.50x15 TSL/SX's. Just my 2 cents, take it or leave it. Hope this helps.
  4. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    So throw the matching gears in there for now and save for the 60.
  5. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    In my opinion if you have the money to buy upgrades for ten bolt then you can prolly throw in a little more and get a 60 unless you just want a 10 bolt. that is why I have neither. I would love a dana 60 but because of my money situation and the fact that I just swapped in my dana 44 I prolly wont have one for a while.
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i spent the cash to regear as well as stick a lockright in mine. very happy with that decision. 60 will be cool someday though.
    ive blown up 1 ujoint so far.
  7. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    One thing with 10b, the dif hsg is not as deep, more clearance. For trail work, 10b may be best. 10b, LockRite, Spicer760X, WARN Premium, WARN clutch rings, 3:42s, 34.5 tires, 15PSI, 1/2T Burb, 350/TH350/NP208.
  8. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i wouldnt put anymore than say $400-500 in a 10 bolt. anymore than that, and you are 50-75% there towards a 60.
    a 14ff would be nice to avoid breakage in the rear so you can get home at least on the rear axle.
  9. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    dont forget premo ball joints as the cheepys dont like the abuse to much. i have seen a few with poped ball joints .
  10. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Are these u-joints you speak of the same size as stock or will I need new axles to go with?
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    The u-joints they are talking about are the axle shaft u-joints and you cannot fit any bigger u-joints (aftermarket or not) into a 10 bolt or dana 44 because the knuckles are not big enough. The u-joint, stub shaft or locking hub are generally considered the weak point on a 10 bolt or dana 44 front.
  12. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    O.K makes since,I did'nt know if you could some larger ones in there or not.Thanks for clarifyin!!!
  13. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Leave it open, run some good u-joints and get some spare shafts and spiders. I ran mine (dana 44) this way for two years with 37'' boggers and it didnt break to often for how much I thrashed it. Dont spend much and save for a 60!!
  14. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    how much does a lockrite + some bling shafts cost? Thats right, more than a D60. Get the 60. :grin:
    j
  15. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    :waytogo: Well thts the plan ,go for the 60
  16. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    If you do the math, fixing up a ten bolt will be a lot less than going with a 60.
    How often do you break the 10 bolt ? 1/2 ton stuff is six lug, 15 inch wheels. One ton is eight lug, 16 or 16.5 wheels. Plan on tires & wheels. Unless the axle gods drop a fresh d60 in your lap your gonna need to freshen it up and will need matching gears and maybe new brake pads. So now you have an eight lug front, what about the rear. If you like to do things right, by the time your done you'll have spent a couple grand doing a clean job. I have hot rodded 10 bolts that I bought from one of the guys in this thread when he went 1 ton. They serve me very well. I would like to go d60 and 14 bolt not cause I'm a hardcore rock monkey but I sure could use the bigger brakes when I tow my boat. Next for me will be 14 bolt w/rear disc and change the front to 3/4 ton eight lug.
