Been away from CK5 for awhile
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by k2-k5, Oct 9, 2006.
  1. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    Hey all!
    Been on Hiatus for awhile. I finally got around to renewing my membership.
    I will soon be firing up the BB454 swap
    Cheers.
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    i am going through the swap now. Putting my 454, th400, doubler and 1 tons into a 71. I am digging the project though, can't wait to get it all together! Any pics there?
  3. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Hey neighbor! Welcome back.
    Make sure you post pics of your progress :D !!
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    You will definitely enjoy the bbc - post some pics when you can.
  5. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Hey welcome back!
    How's that gas tank I sold you holding up?
  6. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    Gas tanks good. No leaks!
    This project is taking way too long. Started it in April averaging about one day a week to work on it. Doing the BBC and the doubler seemed like a good idea at the time. Now I'm not sure.
  7. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    WOW :eek1: :eek1:
    Looking good! My rig is in a sad state right now - just about ready to pull body of the frame to powdercoat the frame.
    Yours looks awesome!
  8. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Your motor sits in there real well. What engine crossmember are you using and did you move the engine forward?
  9. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    I used 73+ (like burt4x4) horns and crossmember. I positioned the motor mounts as far forward in the slots as possible. sits in thre nice and tight with no mods to the firewall. I did put a 1" body lift on for clearance at the th400 adapter and floor pan. I will still have to lower the transfer case some and then may see some interference at the firewall but it should be minimal.
  10. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    What gears did you go with in those axles?
    Nice blazer, welcome back.
  11. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    SaaaaaaWeeet, I'm a little jealous.
    Nice work
  12. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    Man, very clean rig :D !!
  13. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    Thanks,
    Gears are 4.10's
  14. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    How's the doubler install coming along?
    Any idea of what the final weight with that big block is gonna be?
  15. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    The doubler is all installed with the exception of a second crossmember which I got last weekend from a member.
    The front clip is also back on.
    Is see that you got TH400 in your '71. Any chance you can take a picture of the shifter linkage at the transmission. Are you using the shifter on the column?
  16. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    I'm using a Lokar cable kit, yes shifting from the column.
  17. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    How well did the doubler fit with the 1" body lift? got any pics?
  18. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    How about a picture at the connection at the transmission. How much was the cable kit?
  19. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    The doubler fit just ok. I knotched some sheet metal underneith and angled the engine down for a 5 degree slope at the output of the transfer case. I have probably a 1/4" -3/8" clearance from anything hitting the floor.
  20. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Nice!
