Before and after
Discussion in 'The Garage' started by Chaddy, Jul 3, 2006.
  1. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    From the day I got it 6 years ago till now and Im not even close to done.:D
  2. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    You took the top off and painted your rims black? :D
    J/K How about some specs so we know the amount of work you put into it.
    -Avery
  3. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Ok well the first thing I did was a 4inch skyjacker spring lift, then I decided to do a 3/4 ton swapp and that was kool for a while and then CK5 took over!!:D Did a SYE on the 241 and clocked the thing flat,Ord disc brake swapp on the 14ff which made a big diff (no pun intended haha) put a 60 up front with Detroits front and rear, Ord crossover,Ord steering Braces, custom 3inch exaust, shaved the axles for a little more clearance, 2 piece front DL with 1410 joints for pinion angle, and some bashing on the rocks:D
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    You forgot about you custom modified rocker panels
  5. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    hahah Oh ya I cant forget about those:D they took some serious fabbin
