Before i bolt in the 60 what else should i know....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, May 16, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Going with a 4" tc lift. Anything that can help me along would be great. thanks
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Umm, lets see. Dana 60 use the same banjo bolts as 10 bolts, You will get about 3/4 of an inch lift from the axle alone. You should probably put new kingpin bushings and springs in. Don't know what condition yours in, but that one is a must. U-bolts, springs plates and studs and you should be good to go. Also will need some steering correction. Good luck. /forums/images/graemlins/thumb.gif
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    you should know my address so that you can send them to me. Yea make sure to replace trhings now when its not under the truck. Its alot easier to do it now then later.
    Nick
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    the 60 has 20k on it and is good to go. Do need hubs thow. I have the k30 its conming from so lots of little stuff i need, i have.
    mike
  5. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    I was just about to make a post about that. I thought my front end looked a bit higher after I put my 60 in yesterday, but I thought maybe it was my imagination. /forums/images/graemlins/smirk.gif
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    By the time i am done i will have about a 6" lift then. Nice!!
