Before I drop the tank...fuel pump??
Discussion in 'The Garage' started by driney, Nov 5, 2005.
  1. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    My truck will run about 10 seconds and then the engine dies. I hooked up a fuel pressure gauge and pressure starts out about 12-13 lbs and then starts falling off. New filter, same thing. This pump and strainer is only 3-4 months old. Is there anything I'm overlooking before I replace the fuel pump?
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Double check the voltage at the relay, or before the pump, make sure that is not falling off too.
