Before I place pistol next to my head...
Discussion in 'The Garage' started by caleb22, Nov 6, 2005.
  1. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    Please give me some good news.
    Besides the heck of a time and 5 hour search I had finding someone to mount my US Wheel chrome rims to my new Goodyear 33x12.50x15 MTR's, I now have the problem of mounting them on my 89 Blazer. When I placed the tire/rim on the Blazer it touches the brake caliber, thus not allowing the wheel to go all the way on. When I ordered the rims I made sure and checked the backspacing I needed before I placed the order.
    What in the world can I do to fix this dilemma? Let me know what info you may need to help me...guns loaded, just sitting here with it cocked.
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,623
    612
    Hooper, Utah 84315
    Grinder= problem fixed.
    just grind down some of the caliper
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. caleb22
    Apr 15, 2005
    193
    SC
    I started the grind process on the driver side wheel caliper. I spun the wheel a few times and found the high spots. However, after a small amount of grinding I have realized that a large amount will need to be done to the caliper on the side.
    Would it be against any safety rules for me to use a 1" spacer in the front to get the clearance I need? I just ordered a 2" spacer for the rear from Harold's.
  5. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Keep grinding, there is a lot of meat on the caliper...
    rene
  6. caleb22
    Apr 15, 2005
    193
    SC
    The problem I see is that there are two bolts that hold the caliper on (I'm not a brake guy so forgive me). I'll have to grind them too.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Uhhh, what? You have pics? What's the backspacing on the wheels and what axles do you have?
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    might have been good for someone to ask that kind of question before giving advice. :rolleyes:
  9. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    ditto
  10. caleb22
    Apr 15, 2005
    193
    SC
    89 Blazer, 6 lug, and the rims I got have a 4 3/4 backspace to them, 15".
  11. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    are the wheels 8" or 10" wide. For 8", i believe you need 3 5/8" backspacing. i don't know about 10"s.
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I do not know about 4 3/4 backspacing but I do know that a 15X8 with 4 1/4" backspacing will fit with no problem on your setup. I have to grind the **** out of my front 60 to get the same combo to fit.
    Ira
  13. caleb22
    Apr 15, 2005
    193
    SC
    These are the specs of what I bought:
    Brand:U.S. WheelProduct Line:U.S. Wheel 97 Series Chrome Modular WheelsRim Diameter (in):15Rim Width (in):8.00Backspacing (in):4.75Beadlock Functional:NoBeadlock Included:NoRim Material:SteelCenter Material:SteelWheel Finish:ChromeLug Nut Seat Style:Conical seatWheel Construction:2-pieceConical Seat Taper:60 degreeHub Centric:NoCenter Bore Diameter (in):4.28Center Cap Included:NoOffset (mm):+6Valve Stems Included:NoQuantity:Sold individually.
    Wheel, Chrome Modular, 15 in. x 8 in., 6 x 5.5 in. Bolt Circle, 4 3/4 in. Backspace
    Do I need to return these and get ones with 4 1/4 or 3 5/8 backspace?
  14. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i woulda got 4 .25
  15. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    X2 :D I know that isn't what you wanted to hear though. DO NOT grind the caliper cross bolts
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Did you say 6 lug, as in 1/2 ton? Should be no grinding required. But, 4.75" back spacing is a bit much...
  17. caleb22
    Apr 15, 2005
    193
    SC
    Will these work? I'll just sell the other ones...
    Rim Width (in):8.00
    Backspacing (in):3.75
    Material:SteelWheel
    Wheel, Chrome Modular, 15 in. x 8 in., 6 x 5.5 in. Bolt Circle, 3 3/4 in. Backspace
  18. sandawgk5
    Oct 28, 2003
    6,881
    Ya they sure will. The only problem with your other wheels is you are hitting the dropwell of the rim with the caliper due to the large backspacing. 3 3/4" backspacing will keep your scrub radius near what it is with stock wheels.
    Ira
