Begin winch relocation and new CUCV shackles
Discussion in 'The Garage' started by sandawgk5, Aug 5, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I started my winch relocation today and removed my cow catcher bumper infavor of some CUCV shackle mounts:D . I did not get much done as I have a party to go to but so far the winch is relocated........
    To the garage:D . I have front and rear bumpers pulled as well as my hitch in the rear. The front hangers bolted right up but the rear will need some modification as the frames are dif between CUCV pickups and K5s:doah: .
    Now for some pics.
    This is the new location of the winch:D
    Before
    When it is all done the winch will be between the frame rails and I will incorporate a fairlead mount into the mounts for the shackle hangers. I did not realize how much that old bumper got in the way:doah: .
    Ira
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    You'll love the winch relocation. It is one of the best mods I have done :waytogo:
  3. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    For sure. Mine isn't between the frame rails, but I cut out a bunch of the front end and put it way back in there on top of the frame and made a cradel out of 1/4 steel. Works great, didn't affect approach angel at all. Like it there a lot.
  4. sandawgk5
    Oct 28, 2003
    6,881
    How did you work the clutch lever? Do you just power out the line and not free wheel it or did you rig up a new lever? Also any pics you could show me of how you mounted it would be great.
    Ira
  5. 1977k5
    May 26, 2003
    9,992
    130
    I still have use of the clutch lever. I cut the grill pretty significantly to fit the winch in there. I made sure to relocate and keep the Chevy badge though, wouldn't be much of a truck without that! :haha:
    As far as relocating the winch, I had a few ideas. Initially the winch plate bolted under the frame and stuck out big time. I bashed that thing all over the place. My first thought was to bolt the winch plate on top of the frame but decided against it because I thought there would be too much leverage on the frame the the bolts that would hold it on. My compromise was to cut a slot in the frame and slide the winch mounts through the slots and then drill new holes for the bolts. I then decided to weld it all up to give it some more strength but left some bolts in there just in case (the winch can still be removed if need be).
    I ended up moving the winch back about 6" and up about 4" IIRC. It is moved back about as far as it can be without moving the radiator (there is only ~1/2" clearance between the winch and the radiator). The only problem I see with the way I did this is the potential for the frame to crack where I slotted it, but that may not be an issue. I did this swap about a year ago and it has been wheeled pretty hard during that time with no issues.
    The first pic is the old winch mount and bumper. The last 3 are how it is now (looks like it could use a little rattle can touch). I don't plan on adding anything as far as a bumper because I will taper the front this winter.
  6. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Yep...Just like mine. Mine is maybe 2.5 inches higher, but I have a 9000i so our lines prob come out at the same level. I didn't slot the frame or anything cool, just 6 1/2 in grade eights hold the cradel on the frame and 4 grade 8s hold the winch in the cradel. Surly the cable will bust before all those bolts. Not that that is desierable. I ALWAYS put a weight on the line when I winch. Safty first, right?
  7. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    How well does that 8274 work on the K5? Any problems with it being too light for the truck? Just finished putting one together and I've been thinking about putting it on mine.
  8. 1977k5
    May 26, 2003
    9,992
    130
    It's a freakin' hoss! It's widely considered the best winch ever made and underrated at 8000 lbs. Trust me, you won't regret putting one on a K5!
  9. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    chris thats a badass setup anymore pics???
  10. 1977k5
    May 26, 2003
    9,992
    130
    I don't have any more pictures from when I moved it but the winch is still in the same place. What do you want pictures of?
  11. twoslo4five0
    Oct 5, 2006
    6,614
    71
    just everything...just getting ideas..
