BEGINNING OF THE CAT'S?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CHEVY 4WD, Nov 17, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    BEGINNING OF THE CAT\'S?
    When did Chevrolet start putting cats on trucks and blazers?
  2. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    Re: BEGINNING OF THE CAT\'S?
    I think 1978 is when the EPA required cats on all vehicles. My uncle has a 77' Silverado and whenever he got new mufflers put on, they didn't require a cat. Hope this helps.
    Matt
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    My Mother bought a new K/5 in '78 and had no cats,I have a '78 with no cats.I believe that Cali started in '77 or so.Mike
  4. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    in california it was definately '78 for most 4x4's...(chevy)
    in other states it must have been 79 or later
    the reason i say most 4x4s is because I beleive 2WDs may have had cats earlier but im not positive, and heavy GVW trucks may have been cat less even in 78.. but im talking K5/K10/K20 here....
    mike
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    My 77 HD C20 had a catalytic converter. However, it had none of the other emissions stuff.
    I lied. It had a canister but it was only for the gas tank. It didn't even have an EGR valve.
    Starting in 1975 all vehicles with GVW 6,000lbs and under got a catalytic converter. In 1979 the weight was raised to 8500lbs. If they were above those weights sometimes they got them and sometimes they didn't. For example, my 77 weighed 4800lbs. You can't tell me it didn't have a GVW of less than 6000lbs. I went looking for the title but all I could find is the RPO sticker. Perhaps I threw the title away after I torched the truck. hmm.
