belhousing bolt removal suggestions
Discussion in 'The Garage' started by beater_k20, Oct 14, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    really long storty, but in attempting to remove my exhaust manifolds from my K20, i resorted to pulling the engine and swapping in the 305 that i have laying in the garage. i cant get to the bolts from the top, or the bottom. i'm thinking if i leave the motor mount bolts in, and remove the crossmember bolts under the transfer case i should be able to swing everything down to give me better access to the bolts. anybody got any better suggestions?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    removing the crosmember works pretty good, thats how i normaly do it on s-10's and there a little bit tighter than a fullsize
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'd imagine the titanic would be a little lighter than that 350/203 combo.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yea its pretty heavy, but i installed it with out taking the crossmember off figure that one out:wink1: Real fun is making a 203 fit into a s-10
  5. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    That always worked good for me BUT just a bit of advice, if you go this root, pop the distributer cap off as it may break if you lower the back end of the motor to much (don't ask how I know that:doah: )
    Another option, If it's not a show rig and you have a hole saw, measure out on your firewall where the bolts are on your tranny in relation to your firewall and drill some 1" holes, then just gets some plugs to cover them when done.
    I did this when I had a SBC in my S-10, made it really easy for doing tranny swaps. Hope that helps a bit.
    Regards
    Ryan
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i sold my spare 350-203 to a buddy who put it into an S10. to say it was a tight fit would be an understatement.
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its a work truck right now, but being that it was my grandfather's, this year will be its last pushing snow, so the holesaw trick is a no go. 30 years pushing snow is plenty, i think the old girl has had enough.
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Tranny tunnel doesn't unbolt?
    Rene
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    truck is factory 350/203, i didnt think they had removable humps. :confused: maybe i should check into that. :dunno:
  10. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if the truck is old enough to have a 203 it should have the removable tranny tunnel, my 79 jimmy had one
  11. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    My 81 Jimmy has the removable tranny hump. Makes Bell bolts cake...
    Rene
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, it does... also found some scotch locks in the rear light harness that i didnt notice before. makes me wanna strip the entire thing down that much more. :mad:
    this thing is going to be so sweet after i completely redo it, but its a major piece right now.
  13. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    You should find getting to the bellhousing bolts quite easy now...of course you will have the extra work of removing the tranny hump.
    Rene
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and the carpet, and the seat.... ah well, that's easy stuff.
  15. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    I use a ratcheting box end wrench and get the top two and on the other 4 I use an 18" extension with a wobble socket from underneath
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    tried both, and coudlnt get them. something about being on there for 30 years in a wet salty environment i think. i was able to get the lower ones with an impact.
  17. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    ya i didn't realize my tranny tunnel unbolted when i did my engine swap, but a few months later when i did the 465 swap, i took the tunnel out. sure enough those bolts are cake now.
  18. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I just use about 3' of extensions and a wobble on the end. Makes it a VERY easy job.
  19. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Thats how i do it, hasn't failed me yet.
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    already been down the extension and wobble route, no worky...
