Bell Housing & Starter Mounting???>>>>
Discussion in 'The Garage' started by Burt4x4, Mar 11, 2004.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Which is better
    Starter that bolts into the bellhousing
    Starter that bolts into the engine block
    or
    shutup Burt it doesn't matter as long as it spins the engine! /forums/images/graemlins/ignore.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Which is better
    or
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    Bill
  3. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Which is better
    I don't think it matters but,
    Starter that bolts into the bell-housing
    Usually a cast bell-housing
    usually an aluminium unit and i think if your running a scatter shield you need it this way too.
    Or I have no idea and I'm just talking out my ass.
  4. Burt4x4
    6,854
    Scatter Shield? Do you mean the half moon shield that goes on the bottom? Ya I have the cast one that the starter mounts too bolted to my 465 with the shild, actually two shields.
    The 454 I got had a starter bolted to it's block. So got me thinkin... /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif I wonder wich is stronger?
    I have heard the Cast Iron is stronger than the Cast Aluminum bell.
    It shouldn't matter that I am installing a block that use to have the block mounted starter but will now use the bell mounted starter..right???? /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/dunno.gif
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Post up a pic, ive never seen a starter mounted to the bellhousing. Only to the block. Course ive only dealt w/ auto's.
  6. Burt4x4
    6,854
    I have a pic on my home computer, at work right now, I'll see if I can get my wife to email it too me...somewere in the mid 70s GM switched to block mounted starters.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    72 were all still bolted to cast iron manual tran bellhousing for a fact
    housings and starter noses aere all iron still
    i just threw away a bunch of these starters, new ones even, got tired of looking at them, maybe i should have saved just one cuz i just found out today i am most likely getting a 68 C20 pickup that just needs engine put in and its got 465 tranny, so hmm,.,.
    good luck
